flyag1
Quote from: gmeast on September 18, 2008, 04:09:50 PM
Hi Mr.Tesla,
Understood.  The CDI Plasma requires more.  Most not familiar with electronics or components will be intimidated.  I am concentrating on simplifying but it's just about there.  There will be no way around it.  A CDI is a different animal.  It will require putting an electronic pick up in place of the points in the distributor.   It's not for the faint of heart.  You'll just have to wait and see how successful the Nexus circuit is if you want a bolt-on or drop-in system.  As Groundloop said, "...the two circuits cannot be compared..."  I have a feeling that proper integration of these principles into modern vehicle will only be possible on the manufacturing level.
Thanks for your comments.  Peace,
Greg
Greg, I have to almost agree with your statement: "integration of principles only possible on manufacturing level"
It seems to me (reading from multiple sights and threads) most modifiers are trying to force stock components to comply to new rules as opposed to replacing components with simplified high performance aftermarket components.  No computer is needed to burn fuel and make power... for those who don't believe all you have to do is go down to the local drag strip and look under a hood or two... It may well be simpler to remove and replace the complete distributor systems  as well as intake systems of late model ice.  Go back to simple throttle body systems and cam timed distributes...  the cost to replace components may end up being less than paying to manipulate the on board computers.
Getting around the rules as currently stated by the EPA is a different matter.  Its going to take a total re-write of the laws for compliance... luckily for me I live in a state whereby no mandate exist for annual emissions testing:)
I am still trying to decide what system / systems to try and replicate... HHO and / or Plasma...  so far nothing stands out as the right choice :-\  But when I do decide I will not be restricted to using the manufactures stock components...
C the Light,
Area 51
Quote from: happyvalley808 on September 18, 2008, 03:59:32 PM
@All,
S1R says he solved the surging problem in his water motor....
> The problem of the surging has been found. In all the time looking
> into the electrical parts as the problem I got ta thinking. Whats
> deferent in all of the applications on all the engines that have
been
> tested.
> The Elcamino and the generator are useing the same parts, the
relays.
> why wont the new stuff do the same? Well looking at the whole
> at once and its hard to see the small details of the system. I
called
> every one who tested the new stuff and they all had the same answer.
> ( None of the test engines , mine encluded, were set up so the
> exhaust would be run back to the intake and be reused. )
> I was looking over Stan Meyers work when I took notice of this. In
> his notes it showed that the injectors he used also had other gases
> that were being used, what other gases, I thought on this for a
> while, ( 6 months now ), and came to realize what gases he was
> talking about.
> So I ask some one a question. What would happen if you were to
> seperate water into hydrogen and oxygen and feed just plain air
with
> it then use this inside an ICE engine, what would the exhaust gases
> be? HNOS was the reply. then I ask what would happen if these gases
> were exhuasted and directed back into the intake of the same
engine,
> what would the results be as the exhaust gases were combined with
the
> first gas mixtures to the intake then burned in the engine? Answer-
A
> constant incress of NOS build up as if you were useing a
pressureized
> tank to feed the gas to the engine, and combined with the
> hydrogen/oxygen mix and water vapor the combustion would be very
fast
> and cause high pressures in the cylinders.
> Now the deferences between the test engines and the other two. None
> of the test engines were feeding the exhaust gases back to the
intake
> to reuse the NOS gas as a booster for the water (hydrogen/oxygen)
> being used.
> The results of this finding as seems many others was over looked by
> me and the others as well.
> A simple thing like reuseing the exhaust gases to help split the
> water at the plug when its fired.
> The missing link. The Elcamino and the generators exhaust run to a
> holding tank and then to the engine again. The NOS is in the water
> its self bonded by the effect of compressed explosion in the
> cylinder.
> I changed my design so it would work. I hope to show it in Flarida
> next month.
> S1R.
I find it funny that he has had the El Camino running on water for 3 years  ::) , but " Oh wait, I forgot I closed loop the exhaust on the El Camino. That's why the motor's are surging now ". What was he thinking, lol. This gets funnier everyday. Just where is "Flarida" anyway?
Power Inverter and relays - $300
1978 El Camino- $5,999
Getting people for 3 years to believe you have it running on water - Priceless
happyvalley808
@Area51,
I understand everyone's frustration, I agree that it's funny he forgets such important factors........I'm not waiting for S1R to do anything, but I will consider what he has to say....
HV
Area 51
Quote from: happyvalley808 on September 18, 2008, 07:00:58 PM
@Area51,
HV
I agree, no one should wait. Also I find it interesting reading his posts, humorous to say the least.  ;)
gmeast
Ok everyone,
This is just some free energy stuff ... energy from the void ... from the vortex ...from the aether ... from the seething vacuum, etc.
I posted a video and proposed some conclusions about what initiates the plasma burst we're all working on.
This was just fun to do. Nothing scientific, just interesting.
The video:
http://www.youtube.com/watch?v=HB247Gy4Mg4
Peace,
Greg
