Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
sirmikey1
Tesla's Magnifying Transmitter  AKA: Gray's Tube, Swiss Testatica Secret
Notes Below Taken from Peter Lindemann's Movie Presentation
"The Free Energy Secrets of Cold Electricity"
(Link removed by Moderator... Please don´t post hacked copyrighted materials)
The current magnifying transmitter is an air-core, multiple-resonant transformer
that can generate very high KV voltages. Tesla originally termed it self-regenerative
resonant transformer, a term that is no longer in general use.
  Tesla accidently discovered an electrostatic supercharging effect, while
trying to verify Hertz discovery of magnetic waves. Learned how to control
and maximise the phenomenon.  Found that pure and gaseious etheric energy
can be fractured away from circuit. A spacially distributed voltage that
radiates away from circuit as light-like ray which charges other surfaces
in the field; an electro radiant event.
  Electrical condenser discharges/explodes in inconceivably very short time,
discharge vibrations at any rate, up to millions per second, to coil forming
primary of transformer of induction coil. Characteristics and Intensities
undreamed of.
  Charging capacitors with HV DC, discharging through magnetically quenched
spark gaps, at extremely high vibrations, millions per second. This was the
method Operating his magnifying transmitter, and this is the process which
produces and captures radiant energy.  Perpendicular to flow of current.
Produces a spacially distributed voltage thousands of times higher than
initial spark voltage. Produces Longitudnal electrostatic light-like ray,
behaves like incompressable gas.
  Electro-radiant solely characterised by impulse duration. Penetrate all
materials, create responses, electron movements.  Electro radiant impulses
shorter than 100ms are completely safe to handle, will not cause harm. Impulses
shorter than 100ns are cold, cause lighting effects in vacuum globes.  This Gain
mechanism is the basis of his magnifying transmitter. A means to control the impulse
duration.
Tesla tower was planned to power entire earth.  Gray's device was planned
to power your home. Both were using the magnifying transformer.
Negative entrophy: Dead Short spark causes extreme amplification. Coil to
Magnetically Quenched Spark Gap (ether gas).
Electricity is an Incompressable fluid.
Tesla himself told us in his patents that their are two diffrent types or particles.
One is electron other is aether. If you block electron via a super fast charge gap
with over 1 million cycles and 100KV then cold electricity appear from the pure
flux of aether. No electron can go that fast. So the thing is purify the electron from
the aether. This can be done only via a spark with smaller duration than 10 MHz.
So all your curcuits are useless in this realm. If you know some cercuit with more
than 10Mhz to make also high voltages then tell me.
http://www.pat2pdf.org/patents/pat593138.pdf
http://www.pat2pdf.org/patents/pat645576.pdf
http://www.pat2pdf.org/patents/pat00787412.pdf
List of Tesla patents (patent list)
http://en.wikipedia.org/wiki/List_of_Tesla_patents
Cal
amigo
I think there's a mix-up about the frequencies...
Tesla observed distinct colour changes in the discharge space when each impulse range had been reached or crossed:
- trains of impulses each exceeding 0.1 ms duration produced pain and mechanical pressures, objects visibly vibrated and even moved as the force field drove them along, thin wires exploded into vapour.
- pain and physical movements ceased when impulses of 100 us or less were produced, could not be sensed and were safe, passing through all matter regardless of composition.
- with impulses of 1 us duration strong physiological heat was sensed
- further decreases in impulse brought spontaneous illuminations capable of filling rooms and vacuum gloves with white light, appearance of effects inherent in sunlight.
Shorter impulses produced cool room penetrating breezes, with accompanying uplift in mood and awareness.
I do not believe that these effects are far from reality. Personally I do not have an environment and resources to try and replicate on that level, I wish I did. If Tesla has done it 100 years ago, we can do it today. After all he did leave us enough text about it...
sirmikey1
Amigo,
   Paul Bowman (Swiss Testatica) and EV Gray (Gray's Tube) have
already replicated the device, but have kept it secret.  The video I mentioned
above, Lindemann gives clear explanation on replication, and so hopefully
the journey will now begin (prominence).
Regarding such a toy box, KV transformers are easy to find, but how does
one find pulse width modulators of such duration?  Would the standard toy
plasma tube power supply be anything close?  The conversion tube and
condensor seem relatively simple to duplicate.
  I just want to see Tesla's white spiked spark rod.
Cheers
SM
amigo
I often wonder about it as well and by our standards Tesla used primitive means. All he had available to him were inductors and capacitors, the devices of his time. There were no semiconductor or any other fancy technology that we have today.
And yet, with just those two he was able to concoct multipurpose devices (for example that Ozone producing apparatus where the motor acts like an inductance, air mover and a rotary disruptor is just ingenious).
Let's not forget that he was building custom motors for his experiments, custom vacuum bulbs and what not. How many of us can afford that luxury (or go that far). We need something - we go and buy it in a store. It's already pre-made for us, which is a blessing on one hand, and a curse on the other because it is not customized to the specific circuit or device but more generic.
Perhaps it would be worth while looking into rotary spark-gaps and rotary disruptors as means of achieving short impulses. It appears that the spark gap is the only device to my knowledge that bridges the aetheric and magnetic realms, allowing the passing of the first and blocking the later.
What we need is a modern device that can achieve the same effects, if such thing is possible, because spark-gaps aren't really practical anymore, in my humble opinion...
I think I'm starting to ramble...it's late so I'll call it a night. :)
