Simple to make Hilden-Brand style motor
Started by Nali2001, April 13, 2007, 03:40:34 PM
i_ron
Quote from: altium on October 14, 2008, 06:49:38 PM
One simple question, gentlemans:
Do you achieve bigger mechanical output than electrical power input?????
Altium,
Just speaking for my experiments... I have not reached the stage of a properly working machine...
so no in/out power measurements have been taken.
Ron
Thaelin
   I  did actually get a return out of Flynn Tech about the small motor. I wanted to see about
using it on a bycycle due to size and low power consumption. Well, $2,000 was what I was
quoted!    :o :o :o
   For a 3" motor?  Guess that spelled go away and dont bother me boy. Then you need a
micro controller to get the max function out of it. So I paid $90 for a Bison Worm Gear Motor
and should be just fine. Biggest problem is it likes 5 amps.
thaelin
Quote from: i_ron on October 14, 2008, 11:29:26 AM
Tim,
I have said all I want to at this time. I feel that you have not factored in the 'controlling elite'
A further confirmation of what I say can be found here:
<http://tech.groups.yahoo.com/group/parallelpath/>
There is no information coming out of Flynn. Over a year, or maybe two, ago I wrote to the Flynn motor sales link for information on purchase of the generator... silence... try it yourself....
Incidentally your solid state proposal looks good... but keep in mind Flynn's patent predates
Bearden's.... and no action was taken by Flynn. Would it be possible that they knew, at that time,
that the solid state device would not work? There has never been the slightest indication that this
would work. All the research has been motor/generator focused. Look at the "white paper"
Ron
wizkycho
hi all !
@ larryC - I think you should move magnets more closer to the coil, not in middle between coil and rotor. (for hidenpole motor)
@ i-ron
both wonderfull experiments that more and more prove that magnetic transistor (amplification of flux at output) is real thing.
hopefully Main Stream "science" will be wise enough and recognize this breakthrough. with some Nobel prizes to experimenters here.
I mean it - seriously. after that it can be called science again.
@ergo - please show us some negative experiment since you say it can not be done. although You See effect is real - every experiment
shows positive results.
I have ordered nonoriented E cores. I gave up custom shaped cause i saw this can be done with commonly E cores without compromising
quality of  flux path.
maybe this small COP 3 - 4 is to low for someone but it can (r)evolutionize every aspect of our todays pretty scarry selfheadhurting way of life.
Here, even 2 is much much more ... oh so much more.
many many thanks
Wiz
More experimenters join us
To Infinity - - - and then another mile !
wizkycho
classic windings and classic trafo layout wan't work cause of Mr. Lenz wan't allow it.
But maybe narrow pulsed bucking coils and collecting BEMF at input and output at the same time
Anyway it is proven experimetaly BEMF with magnets included is much more powerfull. there might be something.
Wiz
wizkycho
Yes Torque -> Force -> Energy OUT increasses. Some videos are more than obvious.
Wiz
