gotoluc
Thanks Ash ;D   just testing double voltage at same Joule power, tested for the same period of time for plug wear will be a very important test.
Here is a good online Joule calculator if you need one: http://www.electronics2000.co.uk/calc/calcchrg.php
Oh ya, one more thing, you should get a new set of plugs so you have something to compare with. Also make sure to note down your first test capacitor values and charged voltage.
Thanks mate ;)
Luc
ashtweth_nihilisti
Good points Luc, done got a new set of 4 plugs ;D
Thanks man.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
plasmastudent77
Hi guys
I have had success getting a fuel vapour sytsem to work. Its not related to this topic, but I'm hoping that maybe Luc might find it intersting with his GEET work.
My topic   http://www.overunity.com/index.php?topic=6007.new#new
Cheers
PS77
ashtweth_nihilisti
Thanks plasmastudent77 !!
ill add this to the uni web site for all for you :)
grahamsa
HI all
im new, all the way from south africa. very interested in the plasma spark tech. i have a feeling it is the way forward :)
i have a few questions:
1. it was posted earlier that, running a 30:1 mix and a proper atomisation method, not a carb or injection, would work well and not generate too much heat. WHAT is the correct fuel induction method to use?
2. can the plasma circuitry be used on a modern motor (with out a conventional coil, dizzy setup)?
3. for best results, should the plasma spark be run with a lean petrol mix with water injection and a hho generator?
4. if so what is the best method of water mist injection?
i realize these may be simply questions, but answers will greatly increase my understanding of the tech, as well as give me an idea of the long term goal.
many thanks!
