0 Members and 20 Guests are viewing this topic.
giantkiller
giantkiller
Earlier back many pages. I don't recall anybody else mentioning this.
My famous statement is could be wrong!
With the square wave appeared BEMF.
With the two beat frequencies, SM3 & SM6 uses one then the earth's. The SM17 uses 2 of it's own. The 17" is not cylindrically at the wavelength of the freq inherent with the earth. The other two are. Now with any two freqs against each other there appearsa harmonic.
The idea here was to get the Kick from each BEMF to harmonize at the coil edge. That is 3 of the elements needed. The fourth element is tuning which now the collector/antennaes at the right distance would be of the correct parameters to be in tune with the Freak wave harmonic.
Thus power out. The fifth element is us. Just like the movie. What are the potentials.
I stated this before. Search on Freak wave.
I also posted a wave testing site to allow the simulations of harmonics. Did anybody go there? Has anybody read anything?
I don't want to see anybody waste their time. This work is very relevent. With the potential products and applications that I previously mentioned I see this variable high speed magnetic vortex the next big leap for mankind. The SM devices are just a part.
Could I be wrong?
Thank you for your time. I'll put my head down now...
Quote from: ctglabs on October 09, 2006, 03:54:53 PM
Quote from: hartiberlin on October 09, 2006, 03:45:03 PM
Dave, you did put the 2 first transformers in parallel.
This way the voltages will not add.
You must put them in series.
But as the impedance will also add, there is no power gain !
Please can you try th circuit I suggested with 2 noise generators into
the 2 x 12 Volts coils out of phase and post the voltage at the 240 Volts coil output ?
Many thanks.
Stefan,
The two transformers were in PARALLEL!  The voltages ADDs when the signals are IN PHASE 100%.
Well Dave, in your earlier posted schematics, you didput the first 2 transformer?s output coils in series,
then the voltage adds up, but not, when you put them in parallel,
then only the output current adds up.
You probably mixed this up..
Regards, Stefan.
P.S: Have a nice holiday !
Mr_Video
I have no idea what I would be looking for (even if I was set up to build a pwr supply),
but I think I would know if something is happening that's not SUPPOSED to be happening ,
and if SM could find it, then so could we .
giantkiller
Here are 2 shots of my progress.
The coil (PE6-1), driver board, logic board, power supply, clock timer control, and coil driver cables and a coil to coil jumper.
