Magnetic OU principle, You should really take a look at this !
Started by Butch, July 02, 2008, 01:01:34 PM
Bennyboy
@newton2
Fair enough then....at least it's not a randomly generated response (I think).
What nationality are you mate, as Broli says, your vocab is very unusual.
spinner
41 pages later, and no proof for the OU by this "effect"? Why is it so obvious?
A happy New Year to all the people!
Let's get the OU next year...
Cheers!
"Ex nihilo nihil"
newton2
Hello Honoured Profiles
and The Honoured Administrator
of This The Honourable OVER-UNITY-Forum !!
And my especial kind formal Greetings to the
Honoured Profiles : Broli ,  Benny Boy ,   Spinner !
______________________________________________
************YES, to should perform a linguistical "Balancing-Act" between :
##neutrally formulated in-passionate Science-Wordings
and
##NOT to UNveal too much  (yet)
and
##even further to should also "make easier" for Softwares-Languages-Translators
and
##to keep on the "Jolly ENcouraging Moodes"  in-here The OVER-UNITY-Forum.....
and etc , etc.....!
I "just" write per a few Main-Points of PRE-Rough-Sketches..........
using "Schoolars-learned"-Standard-English........!!
YES.......now p.t. THÉ Page 41...........of this interesting important continued
going-on Replies Discussions Rounds founded on the original Page 1 Topic´s
Method´s Idea.......!!
YES........with kind References to The Original Page 1 Topic and to The Honoured Administrator´s Comments...........
IF a Regulary Shaped "common" "short" Solenoides-Coil is "applied" for
"making" H-influenses into the 2 pcs of mu-r-rods........
mutually located fairly CLOSE to each other and "parallel"........
then "should" the 2 pcs mu-r-rods mutually "push" away per H-influensed "Same-Signs-H-poles"
.......following the P1-Method´s Idea , though to use a COIL instead of a nearby Permanent Magnetes to "act" on the 2 pcs mu-r-rods.-............THOUGH HOW THÉN
ABOUT THE INDUCED-H-fields-Alterings as "BACK"
into the COIL (roughly brief populary spoken.......)............
And "HERE" I have to kindly "quit" for further in details-explaning => for NOT to UNveal.........
Though still to kindly hint about :
==>> THE IMPORTANCE OF "CHOOSING"  APPROPRIATE  MOVEMENTS-TRAJECTORIES-
==>> PATHS for The 2 pcs of H-influensed mu-r-Rods...........
==>> WITH ESPECIALLY DEFINED CRITERIAS AS FOR  XXXXXXXXXXX.......!!
YES......by having a "Coil" ACTING ON the 2 pcs mu-r-Rods ,
THÉN such an OU-Methods-Idea might FUNCTION......(I frankly know because of since Y-DEcades ago Self to have demonstrated about.....!!)
Well-then.......a rather OTHERWISELY BASICALLY FOUNDED PROBLEM of Smots and P1-Topic´s Idea is about ,
IF-WHEN to would "use" ALL-MAGNETO-STATICS  Permanent-Magnetes for H-influensing
on the 2 pcs mu-r-Rods.......
(Such a Situation might to a surden "Point" be equivalently evaluated per NOT to would "realize" as H-Poles ,
though instead of  Q-Charges and Masses allocated "in" Positions of "H-poles"......as kept "positioned" per Forces-neutral "Rigid Pins"..........
though such otherwise Evaluations might just be TOO Theoretical.......!!.....)
YES......there are the p.t.-"Our-Times" available numbes of Science/Technics related Words and wordings PLUS Standard-Linguistical Grammars to  could "use" for "explaining in only per Words-Sentences".........
"Fast Made" Drawings on Chalk-Boards ...etc.........might somehow "EN-litten" the WHOLE of Evaluations-"Po-IN-tes" & Aspects........THOUGH INDEED ALSO UN-VEAL about OU-Methods-Ideas.........!!
Allthough i have NOT The Standard-English Language as my First Original Learned Language,
THÉN still "close" in Grammars and Basical Words/Wordings to Standard-English.....etc.....
and I also formulate myself/my "Explanations" if in my "Original Language"=>as "same" as in Standard-English........FOR MUCH OF EXPLANATIVE INFORMATIONS TO SHOULD INCORPORATE INTO LINGUISTICALLY PERFORMED COMPRESSED DENSE FEW NUMBERS OF SENTENCES   !.....
for Who has got Time for Small-Talkings !!........
"Little" or rather indeed much of "Confusions" would be involved if I should attempt "applying" p.t. Sorts of Languages Translators.......!!
Though if somehow......SomeOne Should So Want : THAT I SHOULD WRITE IN SOCALLED CORRECT CANCELLIES WORDINGS & SENTENCES-"FORMINGS".......THÉN O.K........!!
THOUGH THÉN WITHOUT ANY "MEANING" TO THE INNERMOST CORPUS OF THE HONOURABLE COURSE OF OU.....!!
OF COURSE MY "PERSONALLY" APPEARING PERSON IS OF NO REAL IMPORTANCE
COMPARED TO THE  GLORY COURSE OF OU.....!!
I HAVE BEEN DELAYED IN MAKING SOME ELEMENTARY SKETCHES ABOUT SOME ASPECTS OF i.e. OU...........to attach to my Replies.............
though at least I "will" use my Profiles-Photo for a few Days on as meant for depicting "some" Various Technics .....and "some" of  "a-little" of subtle Humors.......!!
My very Person is UN-interesting  UN-important in Aspect of
THE BIG CHALLENGE OF OBTAINING TRUE RELIABLE OU.....
now as in the Y 2009...
and as soon as possible......!!
And THEREFORE I am "glad" about the Possibility of having my nearly-fairly-Anonymous
Profile "here" in OVER-UNITY-Forum.....!!
FOR NOT TO FILL MY REPLIES WITH USE-LESS WORDINGS FURTHER-ON ,
THÉN I KINDLY WROTE FOR A FURTHER OF [ Last Time ]  SUCH
ARRAYS OF NOT-so-OU-related Wordings..........in some Kind of Standard-English.....though....!!
WKR & have Yourselves a nice Day & a pleasant Winter &
Benefits from Your various many hardlabored Doings !
       And my Thanks about Your All important interesting Contributions to
                                   AND
               Your All idealistical Participations in
           THE  HONOURABLE  COURSE  OF  OU   !
                                   AND
     GAINING MORE OF RELIABLE KNOWLEDGES TO THE MANKIND  !
newton2
Might I kindly briefly just mention a "little" about :
************ "Why"/"HOW"-in-fact might a socalled Class-I-closed-Ring-Cores-Transformer
per Elder-Times "Soft-Irons"-mu-r-lamelles-core
and having the Secondary as CLOSED wound "on" the Primary
"even" be "usable" for Audio-Frequencies "Transforming".............
"even" STILL also might for some Elder Transformers also "perform" for
"transforming" on frequencies more than/to some app. 20,000->30,000 Cps frequential Ratings.....!!
!!  ==>> THE  SIGNIFICANT CIRCUMSTANCE ABOUT  CLOSE-nearly-to-100%-H-fields-Couplings
between such CLASS-I-Transformers CLOSELY WOUND to Each-Other of PRIMARY to  SECONDARY as "beseen" "if" as "air-cores"-Primary-Secondary........!! <<==  !!
Well-Then.......THÉN "WHY/HOW"-about "looser" H-fields-fluxes-couplings some "lesser" than 100 %,
more "lesser" than 100 % , etc......if "beseen" as "air-cored"............
if "beseen" as "some" mu-r-materials ALSO appearing CLOSE to "air-cored"-Coils........
if "beseen" as "some" mu-r-materials placed "some" through the "NO-longer-air-cored" Coils´s
Inner-Areas.......etc....etc....!!
Such might perhaps at "easiest" be introductively emperically performed by "Manually-Moving" some mu-r-materials close to/through "Wide Diametres"-Coils/Coils-Systems.......
though of course also might be theorized about per complex Assumptions Calculations about
H-fields when having both mu-r-Materials and Coils.......!!
If deadlines "allow"-for , THÉN perhaps just a little Text some Day some Place in Some Internet-Forum about : The suggested Circumstances of Elder Electronics Vacuum Tubes Audio Sounds...!!
WKR & have Yourselves a nice Day & Weekend and pleasant Winter ;
have Yourselves a Profitable New Year of Benefits from Your various many hardlabored Doings !
Thanks about Your All of Idealistical important Contributions to
The Honourable Course of OU !
Have Yourselves Fruitfull Interesting Experimental & Theoretical Results !
Blainiac
Hey everyone...
I'm not sure why this thread is drying up like it is, this is a fascinating discovery.  Is there anyway this would work?  As you can see in this top-view picture, if you have a rotor (the 'cross' shaped object) and the stator (the ring of plate sections), would the rotor spin fairly freely because the magnets are never leaving the steel, thus no 'wanting to stick' to it effect?
http://nullium.fileave.com/ou.jpg
I conform to non-conformism.
