The heatpump, with more energy out than in (FACT)
Started by Nabo00o, September 19, 2008, 05:56:03 AM
nitinnun
resistance BY ITSELF, causes heat.
that is why a heat pump generates more heat, than electricity is creating.
because the heat pump moved around temperature with resistance, and this resistance creates heat.
resistance causes heat,
and heat causes resistance.
EXACTLY like a magnetic field causes electricity,
and electricity causes a magnetic field.
Nabo00o
Quote from: nitinnun on January 08, 2009, 04:37:13 PM
Yes resistance causes heat, and heat most often increases resistance (at least electrically), but that is not why the heat pump have a COP of 3-5!
I you were to go and try to explain somebody that the reason to why their heat pump makes so much heat is that it first create heat, which than creates friction, which then makes heat and continues infinitely, you would be regarded as a wacko. Not trying to be rude;)
But that equation doesn't add up, and it is not friction which allows this system to have such high efficiency.
If your try to create heat out of friction you need energy, and you will not get more heat than the energy put in, and resistance in a wire is also a form of friction (for the electrons).
The short and simple way to explain it is by saying that the heat pump compresses and therefore heats a volume of air which originally was room temperature (we start with that).
Because the air is so hot it then gives of much of the heat to its uninsulated environment, which heats it up.
Then when the air has almost reached room temperature again, it expands by going through a pressure valve which lowers both the pressure and the temperature. Than it is lead through a room temperature environment which it sucks the heat from, thereby adding heat to the air, which then in the end will be compressed and sent to the heated room or chamber.
So its not based on friction but on a dynamic change between temperature and pressure, while exploiting the difference between the two.
Where the extra energy comes from is still hard to answer, but the process still does what it does, and that is also the reason to why so many million homes uses it has their source of both heat and cooling.
Static energy...
Dynamic energy...
Two forms of the same.
Nabo00o
Guys (and gals :D ), this is a more practical way of doing it: http://www.energeticforum.com/renewable-energy/3383-self-running-ambient-heat-engine.html
And still I ain't quite sure if the energy comes from the outside temperature, in my mind the potential itself is free, but the outside air is the 'medium'. There's a difference.
Here comes the good stuff, a way to use air pressure to create more pressure, its like a heat pump, only that it is made to create high pressure, and uses sharp gradients to make the effect happen!
Index: http://www.aircaraccess.com/index.htm
The technique: http://www.aircaraccess.com/equalizer.htm
A motor using the effect: http://www.aircaraccess.com/nealtank.htm
And tons of pdf files on pneumatics, specifically about free energy:
http://aircaraccess.com/requests1.htm
Static energy...
Dynamic energy...
Nabo00o
I don't know if this should be posted here, it probably needs a new tread (or an entire topic).
But it seems that the heat pump along with so many other inventions uses the same type of technique to generate more energy out of its incoming (physical) energy, and it is the principle of asymmetry.
To you who have heard of Alexander V. Frolov, this might probably make more sense, but time and time reversal effects is actually involved here, and in all other processes which changes the symmetrical interactions between time and space. This is actually what free energy (real free energy) is all about, of course true over unity does not exist because it literally means more in than out (total)!
This is just a hint to you if any of you want to know more about why this works and why current and power consumption in reality is not necessary to power any of our machines and lights.
Also, this will probably not work for complete materialists  ;D ;D ;D
Static energy...
Dynamic energy...
