fcpeace17
Quote from: -[marco]- on October 19, 2006, 06:49:32 PM
hey dave would the radiant field also have the stinging effect?
cause i do remember one time i had the wire glowing and the cat came by.....
he started walking across the wire and looking strange at it.
then the cat even started to tap the wire with its little feet.(offcourse not the copper part!)
it was a bit funny to see but he did notice something.
i think it was something static he felt because of his long hairs.
i switched it off cause i didnt want to hurt the cat offcourse :)
marco
From what i understand radiant energy can have stinging effect it depends on what frequency it is being produced at. Tesla and gray also talk about times when they can touch the field and feel no shock.
starcruiser
I was thinking on how to provide the self starting capability and was thinking of a crystal radio. What if Sm is using a modified crystal radio for the signal source? This can be done using a diode for the detector. The smaller coils in the center would be the tunning coil and the control coil would be the speaker coil. The magnet being brought by the smaller torrid coil would induce the initial kick perhaps? Then the magnetic field generated by the main torrid would be picked up by the smaller torrid thus creating a feedback loop.
Here is a link to a simple circuit diagram
http://www.midnightscience.com/images/cigar/cig_circ.gif
Thoughts?
Carl
Carl
starcruiser
Quote from: -[marco]- on October 20, 2006, 09:36:15 AM
ok so far i have the ignition coil hooked up its not as powerfull as the one i had before but it will do.
ive already had the cd going open and closed by itself also my camera started too take pictures by itself the voltmeter freaks and the lcd display of the laptop goes crazy he also says the network cable is not connected and the mouse stops moving :)
One hell of a magnetic field from that coil eh?
Carl
starcruiser
Quote from: ctglabs on October 20, 2006, 09:25:37 AM
Hi Carl,
I guess he would definatly be using a tuned circuit of some kind in order to receive a starting signal.  But I guess the question is, from where does the extra come?
If you fed the output of crystal radio back to the input, you still have same as you started with, where does the extra come from?
If you do this in a battery powered radio, feed the output back you will end up with a vary large signal, but in the end the power to make that was taken from the battery.
But there is undoubtably a feedback loop as you say...
Dave.
Dave,
I'm thinking that the feedback comes from the main torrid  magnetically coupled to the smaller one. The large torrid is a tuned antenna which provides the amplification which is fed back to the crystal radio, this increase in signal is then re-introduced to the main torrid/antenna thus providing the positive feedback loop. The principle of the crystal radio is just to pickup the strongest signal, the magnet provides some of the amplification I believe. This is something I am willing to check out tonight by building a simple crystal receiver and place it in the core of my coil to see if this hold any "signal"  ;D.
Carl
Carl
