Goat
@ gadgetmall
Thanks again for the information you just provided, the 70 VAC from the piggy back coil is indeed interesting.  I myself have tried many different configurations of the Bedini but none were ever close to what your getting.  Your replication is quite different as I was following most of the original advice of "no departing from the original circuit and components in order to understand the concept" but that never seemed to work for me.
Your circuit however uses much different components as we see that you use heavier wire for the primary than the original circuit(s) and also the use of the neo magnets instead of ceramics, also the use of the bridge rectifiers, caps with neon's, heavy duty diode back feeding etc.
You're quite right in saying that it could probably be replicated using different components like wire instead of welding rods and other things, I'm just trying to post as much information about the original components for posterity.
I think you came up with something that works for you that didn't work for most of us using traditional methods so that's why I'm trying to document as much as possible your circuit and components so that others may eventually come up with a working model such as yours.  Sort of like the ongoing effort in the Joule Thief thread.
Please don't feel pressured to answer all the questions as you made it quite clear that you are a single parent and raising your child should take priority and I certainly wouldn't want you to mess with your original circuit like taking apart the piggy back coil.
Paul
gadgetmall
Hi Goat . Nope this thing was on a platform made of ceramic material or something 3 inches wide and 6 inches long base  . I have the mercury switch somewhere . it Is the same size of the coil core made of aluminum and 4 inches long filled with mercury and heavy and something that slides up and down inside it . it was mounted vertical so gravity held it in the open position and when the coil energizes the thing inside goes up and contacts . it was high amperage stuff in a large control cabinet i still have outside housing my inverters and control electronics for solar ,Bedinipowersupply , inverters and small battery's for charging My 1100 pound 24volt forklift battery ..
gadgetmall
Paul i am flatter that you are trying to replicate the total design of mine but as i stated it runs without the rotor too . And i don't feel pressure and want everyone who wants to use the knowledge i have to make there own self runner . I just can't believe that with all the other self running devices that are made i am the only one to share this information . I can't make money on this because the main design is Johns so i can't claim the Big  overunity dollars even thought i would like too . I am in it for the Power i get for Free not the money . And i will help YOU anyway to prove that what i have here is indeed free power and i'm not another Nut case . I don't lie . i am a Baptist Christian a good father as i have full custody of my Daughter and Love all God Fearing people with a positive outlook . As i said i have been looking for free energy for over 15 years . During that 15 years i became Close to Barbara Hickcox the inventor of a perpetual spiral magnet "cold fusion " generator and was about to have it in my possession before she disappeared off the face of the earth . I have all of the correspondence and plans and a video of the working unit but i promised not to show it because my life would be in danger .You can look up her invention in a patent search . I even Had a web site set up many Years ago describing the device and overunity.com had been in contact with me way back then .I pulled the web pages down as per request  as She did not want the attention and for good reasons  i see now .My Gadgetmall tag of newbie is misleading  :)  !. God Bless ya !
Albert  edit .. OH im a Jr Member now . COOL !
Goat
@ gadgetmall
Whoa  :o  You meant REAL Mercury  :o :o  I hope the mercury container was missing when you got the cabinet!
I was looking at the brand name Mercury but never caught on that it was that type of switch...lol
I just found an old roll of 34 gauge wire I had lying around, I'll wind a spool up and give that a try to see what kind of voltage it gets on the back end of my existing bifilar coil.
Thanks,
Paul
gadgetmall
Whoa  Shocked  You meant REAL Mercury  Shocked Shocked  I hope the mercury container was missing when you got the cabinet!
What do you mean , It still has the mercury in it . from the feel of it about 2 OZ'S of the presious metal . Its sealed up in aluminum and hey i found it here it is !! Now that i look at it and know that mercury eats aluminum i don't thing its aluminum . it must be steel or some other metal . Still works too .
