Identification of the Tempic field Node lengths
Started by libra_spirit, January 21, 2008, 09:37:38 PM
amigo
Hi libra_spirit,
Thanks for your reply, that is very interesting. From my understanding of what you wrote, you are kind of a Radionics detector, to put it bluntly. As you noted we all are sensitive to subtle energies, some more, some less.
The way it works with Radionics, most people in the field generally use external devices such as pendulums or rods, while some do not need them and can use their hands. But there is only a few I would dare to guess who have progressed far enough to use their mind to directly sense these vibrations.
Then again, on second thought, I think our intuition is a perfect example of a subtle energies detector/response circuit, it's just that we choose when to "listen" to it and when not (our fault really, we should always pay attention).
I believe Radionics to be a trained discipline, though some people are more predisposed to it due to whatever factors, as you have probably discovered yourself. And so if I may suggest an experiment, take your "skill" for a ride into another area.
First, if you are not familiar about principles of Radionics, touch up on that, then perform a few simple "dowsing" tasks that in general would be done using a pendulum or a rod. Afterwards compare those results with what the factual answer/response would've been.
I'm interested to know whether it worked or not and in what kind of accuracy as well. Ideally, I would find a partner to be the "control" and impartial observer, and also would pick something you are not intimately connected with as a task, to avoid any possible "contamination" of results due to bias.
What do you think?
libra_spirit
Amigo,
I have a very good contact, a radionics person, he has also verified many of the matrix lengths, and even added others. Now that is a skill. I was more of a Chi person until I discovered these vibrational rods and started to study them. My own curiosity has driven me more then any discipline.
Yes, you have detailed an experiment that you should probably perform. LOL! Accuracy is of paramount importance when opening to the wizard stuff.LOL!  I think that before one just believes, 3 or 4 need to test it also. If all get the same then there is good ground to observe and record patterns. However when a voltage node pops up that can be measured the doubt is over. Further a formula written to determine where it will allways pop up was the cream for me.
There is a device called an AV plug that is connected into a meter. On the Joe Cell feed tubes of strong cells, we can locate these energy nodes, and always just off both sides the pinpoint of voltage will appear using the AV meter. Further a background RF sensing meter will show in the area of a Joe Cell the noise floor drops considerably.
On the actual energy node the EM goes away, as in, there is no EM noise to measure.
So for sensing with meters you look for what is not present.
In sensing with fingers you look for the point of cold or hot or whatever your body feels from them.
The fact is they do not move but are consistently placed within a fractal base system, whether using fingers or meters. Just as fixed as the tip of a pyramid.
The resonant rods bring together both the sensing abilities and science for me.
I have done much of the experimenting you are suggesting and have arrived at my own personal conclusions on these issues, but I do still learn new things constantly. Not that I really want to be the test subject, but lets just say it is possible to be dropped anywhere on planet earth and sense the North, South, East and West directions accurately. For me, N/S pressure on the extended palms, and E/W strong vibrational coupling, especially if you have a resonant rod handy. This is way past the testing phase for me traveling about for the past 20 years and just doing it. If a bird can do it, so can we. These can only be proven to oneself, or others standing by with compass in hand or AV meter to verify. However you won't find many that will offer to be the test subject. I have probably been an exception to this, and documented a lot of these kind of experiments already. My hope is that others will also discover and use some of the data and techniques that have worked.
You may not be able to understand the resonant vibrational rods without trying them for a while, but they may open your sensitivities if you do try them. If anything it is very similiar to feeling quartz crystals, and there is even a length now for resonating quartz crystals, that is quite amazing for those who do sense quarts vibrations. Diamond also now can be vibrated up with a length of wire. Those ones are in the matrix document in a past post. I have a large Aluminum tube now that feels exactly like a quartz crystal when you palm over it!
If you are intrested in doing some of these kind of experiments and documenting them contact me at my email address.
<libra_spirit@hotmail.com>
Thanks,
Dave L
