2tiger
Hi all
In my post I ask you a question about the smaller sm-device:
http://www.overunity.com/index.php/topic,712.msg14577.html#msg14577
But nobody has answer this question, about the amount of the energy such a coil can store.
Now I do some math on this. Please take a look at it and reply if you see any mistakes.
So in theory its possible to store round about 130 Wh in this setup.
You would be able to light a bulb (180v / 100W) for round about one and a half hour.
Perhaps the sm-device is not a generator, perhaps its only very good batterie  ;).
But perhaps I?m complettly wrong!! :-[
kr
2Tiger
mrd10
Hello 2tiger,
weve been making progress with this device, especially from Guys experimenting like Dave, and others. This is not a battery, it is a device which is tuned into a certain frequency and then amplified, to produce power, I don't think modern day calculations will matter here, as it delivers as much power as required, hence thats why it gets warm.
This is pretty much Teslas technology were dealing with here, remember he went against mainline science at the time, as he believed energy was all around us, all we have to do is know how to tap into it. This is what SM's device does.
Ive just been reading about crystal radio sets, there quite easy to make, note they do not require batteries to operate, they get energy from the ether. http://www.arar93.dsl.pipex.com/mds975/Content/aerials1.html
Now look at his second prototype, the rings i believe are loop antenaas:-
The radio is simply placed in the middle of the loop and the signals collected are transferred to the radio via its internal ferrite rod aerial.
The circuit for a loop aerial could not be simpler, being a spiral loop consitsting of 10 turns* of 7/0.2mm 'hook-up' wire wound on the 40cm former, and a tuning capacitor to resonate the loop aerial at different frequencies.
(*about 40 to 50 turns for Long Wave).
If it is required to connect the loop to a radio via its aerial input terminal then a second winding of just 1 turn of wire is wound over the main 10 turn winding.  This secondary winding acts as a coupling coil that is connected to a suitable socket so that a cable can be run from the loop aerial to the radio receiver.
END,
the rings on second version i believe are no more than loop antennas which boost the signals into the 4 collector coils in side the rings, The r8ings do look plastic, so he has the coils hidden inside, and the larger coil on bottom ring is the output.
there is probably differnt ways to make this, and easier would to make a tunning cct which will accept 7.8hz, as SM mentions tuned into earths magnetic field, then magnify/induce this into collector coils which have magnets placed on them.
Once you have this understanding, its easier to start to build it, otherwise you won't know where to start.
From the data ive so far collected and watching videos again especially his first and 2nd proto, and the clear pic Lindsay sent, it all starts to fall into place, And the fact that Dave and others have done really great work with their experiments, just pieces fall into place.
KInd Rgds,
Dom   ;D
mrd10
Here's the plan:-
2nd prototype, how it works:-
1) rings made of plastic, with coil wound inside the plastic to accept Long wave  *about 40 to 50 turns for Long Wave).
read up on this link its excellent, especially on loop antennas:- http://www.arar93.dsl.pipex.com/mds975/Content/crystalsets1.html
2) the rings freq is tuned by cap 7.8hz and rings will resonate at earths magnetic field.
3) 4 collector coils on inside rings with magnets placed to again magnify, and these very likely wired in series as Dave has found out, will cause rotational magnetic field, within the toroid.
4) this field is induced on larger coil winding on bottom ring.
power
Thats it
Dom    ;D
mrd10
I'll re-iterate further with connections, ive been thinking isolation here, like transformer
the 4 coils inside the two resonating rings are connected in series to each other, and thats it, there is no connection elsewhere, just to each other in series    e.g  c1----c2-----c3-----c4----back to c1
the loop antennas 2 x have these 4 coils placed inside, the induction is helped by placing the magnets on these 4 coils, think of magnet assist here. this helps in what is picked up from loop antennas into 4 coils, this gets a rotational field happening which is like jet engine, which sm mentions.
once this starts, its like starting up a generator, this in turn gets induced into larger coil, , so as you can see all coils are magnetically attached, no physical wires to each other....
brilliant
I think Tesla might be talking to my sub conscious or i have a gift....lol
Dom
;D
mrd10
