HHOHHU.com HHO heater. Is it overunity ?
Started by hartiberlin, February 06, 2009, 12:59:24 AM
Mark69
What if you heat a tank of oil( like corn oil or something safe), and have it pumped through a radiator and then return to the heating tank.  Mount an electric fan on the radiator.  Insulate the tubes to and from the tank.  Think of it like in your car.  I think that would allow better thermal transfer.
Mark
pmazz850
As far as the fan cooling the pipes down, One pipe in the center should be longer. And then a piece of flex pipe runs off that through a funnel, to the fan. The fan only pulls heat off the one longer pipe. So the rest of the pipes should stay rather hot. Haven't confirmed it yet, but it should work.
Quote from: woodpecker on February 13, 2009, 12:19:29 PM
I have made some tests with the gas, heating a room:
roomsize: 15 Cubicm., Starttemp. 11 degree celsius
I used 14 coppertubes. Tempture was raised after 30 min at 14 degr.
total Watt used 330
For camparison, i made the same test once more with a electric heater with 450 Watt:
Starttem. 11 degree, after 30 min. Tempt. was raised to 13,5 degree.
So the gas was heating with less Watt a little bit more.
The coppertubes get quite hot, but after installing a little fan, i could touch them with bar hands.
woodpecker
I did this little experiment only out of couriosity, but for future tests, my too, i tend to build something different, like Mark said, with a tank, radiator and oil.
froarty
total Watt used 330
The copper tubes get quite hot, but after installing a little fan, i could touch them with bar hands.
Woodpecker, The recent claims of over unity all deal with circulating monatomic hydrogen through submicron cavities that leverage the Casimir effect. the Casimir effect tries to push the sides of the cavity together if free to move but if braced apart creates an exclusion field that restricts the larger virtual particles in the time stream from flowing through the gap. Black Light Power uses cavities formed when the softer Al is leached out of a Ni-Al alloy heated to 200 C to dissassociate the impregnated hydrogen. Jovian corp is building a prototype that circulates monatomic hydrogen through stacks of conductive & insulating plates with an array of drilled submicron columns all the way through the stack -therefore what can you do at home? exclusion field cavities are hard to build because they want to self aggregate (Darpa is presently funding projects to mitigate this effect because it is limiting their nano toys). This is why BLPs catalyst is a 2 step procedure- create an alloy then leach out the softer metal. So your easiest experiment is to use heat to disassociate the hydrogen in the same pipe sourcing your flame so use a thick long pipe and heat in the middle in case you have leaks at the connectors and instead of killing yourself trying to create a skeletal catalyst experiment with creating "Casimir gaps" - try sand, lime or conductive powders in the heated tube -crystaline would be best- the facets not only create the gaps which would form the casimir geometry but they also allow the gas to diffuse through - there is a property of hydrogen diffusing though metal lattices to become monatomic naturally such that if you had a crystaline metal powder you might not even need to heat the tubes which is the method Jovian is proposing. Or any other method to make your hydrogen monatomic but this is the other reason this process is so difficult to uncover is that hydrogen wants to immediately drop energy and form a molecule -if you keep it monatomic long enough to enter a casimir cavity they become hydrinos appearing to shrink -if they bond while shrunk they cannot freely grow back to normal when exiting the field and nature has to break the bonds restoring the mon atomic energy levels and rearming them for the next cavity - if you have these cavities adjacent to each other like Jovian you can repeat this procedure over and over turning nature into a hydrino thermal rectifier.
Fran
albator10
Hi,
In the XOGEN video on youtube they show 2 way to heat a home
1- Heat a ceramic plate in a forced air heater
2- Heat water
http://www.youtube.com/watch?v=pXo7CVFI5Sk
