New youtube of magnet/coil "perpetual motion"
Started by Hugo Chavez, February 15, 2009, 10:00:13 AM
FreeEnergy
This is a demonstration of concept. Im not prepared at this point to reveal all my secrets. Im concerned that if I present too much information that the authorities will try and discredit me. Right now its just a cute toy. Im sure that you understand.
can you believe this guy?!
classic!
i guess fame is more important than saving the world?
if he doesn't open source this not only will the "authorities" discredit him and probably kill him but will also make it disappear from public never to be seen.
what's next?...his going to go to the patent office? lol classic!
* that's if this is for real and he actually has a working device that is truly free energy/over unity.
Hmm,
now he is selling
Rail Gun DIY kits,
so were these other perpetual wheel videos
just to make some free advertisement for the
Rail Gun kits ?
Would be better ifhe would sell the coils and transistors for the perpetual wheel .
That would be much more interesting and he would sell much more !
Regards, Stefan.
ltseung888
My comments on his video are in:
http://www.overunity.com/index.php?topic=2794.msg159001#msg159001
We shall reproduce his setup and make it demonstrate overunity.  That can be a good teaching tool to complement our flying saucer proof-of-concept set.
sushimoto
Quote from: hartiberlin on February 20, 2009, 11:25:23 PM
Hmm,
now he is selling
Rail Gun DIY kits,
Rail Gun kits ?
Regards, Stefan.
Stefan,
He simply will not sell the coils for two reasons;
first, they dont have much educational effect and
second, they just dont work to build OU.
He is not there to sell much more and nor to supply parts as "DIY Overunity-Kits".
He is a teacher.
For this small set of steel&magnet balls he asks for 5$ in a comic-bubble.
Is that worth to start a big business campaign?
Thats not his mission.
You guys here (as i do) must understand,
that there is a huge gap beetween advanced researchers here and
"common people" outside.
90% of the youth is playing Computergames,
but if electricity fails, they are not able to make a fire
due to the lack of basic knowledge in physics.
These 90% are by far not able to make electricity.
Most people here could at least imagine and construct  a "shaker flashlight"
with a capacitor coil and a magnet.
Maybe, with 5$ of investment, you could get your children
away from Doom or such ego-shooter
to awake some interest in real life.
Its not a gun, but an attractive real-live experience.
best,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
I think I now have a very good idea, how it can work.
Have a look at the following picture.
I borrowed a picture from JL. Naudin´s coil research and modified it.
Dr. Altmann uses pretty big diameter sized permanent magnets.
So if he has 2 coils on the spool, one with a very large turn number coil
with fine wire size and
one very low turn coil with bigger wire diameter,it is a perfect solution.
Now see the induction voltage from the picture when we use a graetz
bridge rectifier on the large turn coil.
This will generate quite a nice induction voltage into a cap after the graetz bridge.
So an incoming rotating magnet can charge up a 100 nF cap behind the graetz bridge probably to
around a few Volts already.
Now comes the tricky part.
To get a good repelling pulse, we have to use the whole cap energy
and have to discharge it in a short amount of time into the second
low turn coil which will be wired in repelling mode.
This can be done by a voltage comparator circuit, in the simplest form
of a zenerdiode to fire the transistor or FET to discharge the cap energy storage
into the low turn number second coil.
As this second coil has a low ohmical resistance the current buildup
is really quick and thus there willbe flowing probably at least an amp
in a few milliseconds for a short period of time, which will
generate a pretty strong repelling magnet field...
So all in all this circuit might work pretty well and it is not so mysterious as
it looks.
It just depends of the 2 coils, what the high turn number coil can generate for an induction voltage
into the cap and then how this stored energy can best be used to repell the passing magnet.
As the magnet is pretty wide in diameter, it is still in the transit, when the cap is already charged after
the pulses from the scopeshot, so coil 2 can still repell it with some force.
So maybe if we make the magnet still wider or use 2 magnets side by side,
the repelling force will be much better, as there will be still enough magnet surface there after
the voltage spikes,so all depends on the setup of the magnets and the coils to each other.
It could also be beneficail to have the 2 coils not on the same spool but to have them side by
side, so the first high turn coil can charge up the cap and then the second low turn
coil can fire the repelling pulse, when it is exactly top dead center over it.
The trick is really to use 2 different turn number coils, as there is the induction voltage
difference of a high turn coil versus a low turn coil, which is okay to charge up the cap.
Regards, Stefan.
