alexlab79
My fist and second drawing
http://i658.photobucket.com/albums/uu302/alexlab79/carbonboronreactor.jpg
http://i658.photobucket.com/albums/uu302/alexlab79/carbonboronreactor2.jpg
The first is my first attempt to understand, standart impulsion in rod and use coil for receive power, but after i read many and many thing about discharge in carbon i have modified my plan..i will try this 2 setup soon. i will post my result..Thanks and scuse for my poor english..i speak in french. :)
Koen1
@Sparks: "macroatoms"? Are you talking about things also referred to as "atom clusters"?
Some interesting research is going on in that field...
And example: it was found that 11 aluminium atoms can cluster together to form a unit that
appears to have the chemical characteristics of a single alkaline metal atom. The clusters
formed bonds with Iodine that typically occur only for such metal atoms and typically do not
occur with aluminium at all. Similar clusters that behave like other atoms were found for
other numbers of Al atoms. unfortunately I do not recall all the exact details at the moment,
but I do recall another number of Al atoms behaved like Gallium. The tests I read about
were only conducted with aluminium atom clusters, but there are a great many elements
and it is now suspected that most can form such clusters that behave like atoms of a
totally different element.
Is that what you are talking about?
@Mike: well there are some other magnetic elements... If you've eliminated iron, cobalt
and nickel, then perhaps you have some neodymium, samarium or dysprosium in there?
And let's see... wasn't Gadolinium ferromagnetic below room temperature? I think so.
But it could be something else of course. I would even suggest that perhaps it could
be GaMnAs (GalliumManganeseArsenide) but I suppose that would dissolve...
regards,
Koen
mikewatson
Koen, my crude analysis using aquarium reagent for iron suggests iron is present plus a number of  other undefined elements. Michio Kushi says in his book that it is best to arc a carbon rod (without water) onto carbon powder in a carbon crucible to get a good yield of iron. The iron seems to contain other elements of the same group, possibly nickel etc. Joe Champion describes a similar process in his book and the results were, I think,  professionally analysed by Bockriss at A&M university. The only way to be sure for the amateur is to get a professional analysis done, which is expensive.
Of course all this is a big no-no for current physics which requires a nuclear reactor or particle accelerator to produce such nuclear changes. If it turns out that changes like this can be produced by low energy sources then the old alchemist was right after all.
The question is what element or combination of elements could be used to get a useful energy output. For example:- the late Paul Brown's patent 4,835,433 "Apparatus for direct conversion of radioactive decay energy to electrical energy", Perhaps a similar system could be used with ordinarily non-radioactive elements such as the VSG carbon reaction although I have had no sucess with that up to now
Mike.
mikewatson
Apparently someone had patented the carbon arc to iron and nickel transmutation process. So it is likely that the magnetic deposit I mentioned in an earlier post is Iron  and Nickel.
Mike
Mem
Quote from: Tesla_2006 on July 31, 2006, 08:15:00 PM
Hello, there is many single electric and electronic circuits can generate controlled nuclear reactions, totally ecology and of low costs, I've tested 3 circuits with full results
1) Discharging a condenser in a carbon rod
When a condenser is discharged in a carbon rod acelerated electrons hit the carbon atoms in a fusion reaction creating Boron in the following reaction
                              C + e = B
For this process is needed a fews Kilo-electronvolts (Kev) of energy powered for the condenser bank
But that Boron atom is a inestable isotop and desintegrates in the original Carbon atom in a reversible reaction
                 B = C + e
This reaction liberates about 13 Mev, and liberates the same electron used for the first reaction but with more energy in a way of beta radiation
Other detail is than for each 100000 atoms is bombarded for this electrons discharge of Carbon only one go in this nuclear reaction, this is know in physics as the coefficient of effectiveness
For a initial volume of carbon rod there is a minimal energy for start this process calculated determinated for the condenser bank  and can get that from a single battery, when this nuclear process begin, electrons in form of beta radiation can be collected for a toroidal coil arround of the carbon rod, that toroid must be in the principle polarized with a little current for align the magnetic dipoles in the carbon rod for help the process
My results was get in the external toroid about 6 KW in my firsts tests and then autopowereds devices at 110 VAC, 60 Hz and 220 VAC, 50 Hz , and I've published some results in a web site, but in spanish   http://econuclear.tk
This single nuclear circuit may be the used for Nikola Tesla in 1931 for power his electric car, because he use a little circuit keep in the radio box and have 2 carbon rods labeled "Here is the power"
2) A magnetic version of the before mentioned discharge device I build using the know nuclear magnetic resonance phenomena, all atoms have a nuclear precesion known as the Larmor precesion frequency, his value for a magnetic field of 0,5 Teslas is about 21 MHz, this suggest than if we create a magnetic circuit tuned to this frequency by the quantum relation E = h * f , the nucleons proton-neutron area break and there is a nuclear desintegration and energy liberation
I test a common iron rod and place 3 coils, one for the polarization field of 0,5 Teslas, another for generate the resonance at 21 MHz and a third for get de power, in my firsts tests I get about 10 KW with the starting polarization and oscillator using less than 100 watts, and autopowered devices to 220 VAC, 50 Hz and 110 VAC, 60 Hz, I see the frequency output is the tuning difference between the resonance Larmor frequency and the external oscillator, thats say if the nuclear resonance is in 21 MHz and the oscillator was at 21,001 MHz the output power frequency is in 1 KHz , I see in this magnetic circuit there is a desintegration of the Fe atom in a isotope for a delay of time for reciver his initial state
This method is used in medicine but not used for energy generation and too many more single than the here shown system use Uranium , this is an ecologyc device and low cost in comparation to that, I wait upload this to the before web site I mentioned
3) Discharge in gases, I've build a gas version of the carbon rod discharge version for proof an aditional phenomena only known in gases discharge, I use a common fluorescent lamp of 8 watts, a battery generator of high voltage with voltage doubler, a condenser discharge into the tube when his voltage exceed the breakdown avalanche state
I can get from the battery about 2 watts but the tube light at full power, thats say 4 times the power of the source
Russians work with the SGD ( Self generating discharge ) in gases for nuclear reactions of the accelerated electrons with the gas atoms
Very single circuit , an oscillator a doubler with a discharge condenser
All this circuits shown there is single electric and electronics circuits, of very low costs get nuclear reactions such as in the nature there is spontaneous nuclear reactions in lighting discharges, carbono 14,etc,.....
Any question to this email I can answer    gigawattgratis@123mail.cl
YOU WICKED MAN FROM CHILI:
JUAN, YOU TOOK MY MONEY AND NEVER SEND WHAT YOU PROMISED!!! YOU LIAR SON OF A BITCH !!!
WARNING EVERYONE: THIS MAN IS A THIEF HE PUT HIS EMAIL ADDRESS  HERE AND HE IS LOOKING FOR VICTIMS. IF YOU SEND HIM EMAIL, HE LATER WILL ASK YOU THAT HE CAN BUILD ONE OF THESE "NUCLEAR POWERED" FREE ENERGY DEVICES, ALL IS B.S. DON'T FALL FOR IT. HE IS CON, AND THIEF. HE SHOULD BE IN JAIL FOR HIS DEEDS.
I HAVE ALL THE EMAILS THAT HE SEND ME FROM CHILI IF ANYONE WOULD LIKE TO SEE IT.
JUAN, YOU WICKED MAN, YOU WILL PAY THE PRICE OF YOUR ILL DEEDS. I AM AFTER YOU TO EXPOSE YOU WHERE YOU GO ON WWW.
IF EVER MEET YOU IN PERSON, YOU WON'T BE ABLE TO WALK AGAIN !!!
