HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
Spewing
500 Rpm, 8.3333333333333333333333333333333 rps
Intake valve openings in one second for one cylinder, 4.15 times per second.
Intake valve stays open an total of 2.075 revs a second.
Every 240 milliseconds the valve on number one cylinder will open.
Time per 1 complet rev, 120 milliseconds. Time to remain open 60 Milliseconds for opening or 249 milliseconds for all 4 openings.
5736 Liters per min, Flow rate, 95.6 cc's per second.
10.4 milliseconds per 1 cc
Total valve open time 249ms / 10.4 23.9 cc's per that half of second. Roughly quick estimate, you need under 11.95 cc's per second per cylinder to run this engine according to your 5 liter claim. you need 71.7 cc's per second flow rate for all 6 cylinders. Estimated Gas to run this engine, Under 4.3 liters. Wasted gas, around 1.3 liters. V6 is bad for health.
See how i quickly calculated that, its not perfect, but it gives you ideal on how to calculate it.
Understand the delivery method used with the one not used. The above is bascily a rough estimate of what you "Was" using to idle your engine, and what you "was" wasting because you improperly delivered it to your engine. V6 is bad for health.
You must direct inject 5.9 cc's per valve opening time into your cylinder, With a smaller single cylinder engine its calculated you must inject atleast 2.4 cc's per valve opening time. Smaller cars is ideal.
Outlawstc
why is v6 bad for health? the cylinders are to small in volume? and never burn all the gas off?
outlawstc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
Spewing
Quote from: Outlawstc on March 05, 2009, 01:28:53 AM
outlawstc
lol, what i meant was you have lots of pistons, theres no need for that... you want to run a car not fly a rocket. My calculations is based on the information you have provided me with,,, if you feel you can produce the 4. whatever i said liters pretty easy then its all luxary, thats what your engine wants, learn how to give it to it.
Study the math, you'll find a spot that seems unclear, it'll come to ya if you think about it, you must have a "mechanical mind."
I just feel like a v6 isn't needed because it uses so much more gas, i mean you have 2 more pistons on it than you would a 4 cylinder, myself, i like my 3 cylinder car, Pisses me off when i cant see around a big v6 LOL.
sushimoto
Quote from: ramset on March 04, 2009, 09:52:08 PM
@all
This topic is HOT smokin hot
A few folks with a secret [profit] agenda are trying to steer it
NO WAY
THERE ARE TO MANY PLACES BUSTING OUT WITH THIS INFO
OPEN SOURCE!!
CHET
Hi,
Is there any text file, which collects relevant information?
Its always better , to save such facts into a file to hard discs for further spreading.
Threads are fragile and easy to disturb by diversifying and such.
best,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
ramset
SUSHIMOTO
The gentle man [H20 power]  is summarizing all info as we speak I will post that when he is finished
Till then here is some very good info[From h20power]
     Like I said the WFC is NOT IMPORTANT it is the GAS PROCESSER that is the key to this technology.
Some numbers for you to think over:
Gasloine has a energy level of 495 kJ/mol
H2 + 1/2O2 has an energy level of 285 kJ/mol
Now this is what happens when it passes through the Gas Processor:
1st ionozation level,
H 1312 + 1/2 O 1313.9 = 1968.85 kJ/mol
2nd for oxygen,
H 1312 + 1/2 O 3388.3 = 3006.15 kJ/mol     "" AN accelerator[as outlined by the user Buzz]""
3rd for oxygen,                                                    [added by chet]
H 1312 + 1/2 O 5300.5 = 3962.25 kJ/mol
Now you can see just what the Gas Processor is doing. Note, depending on how far you ionize the Oxygen the energy levels keep going up to end up with this:
H 1312 + 1/2 O 84,078.0 = 43,351 kJ/mol. Now that's energy
If you get to any one of these energy states it will run your engine with ease. So, the key is to make the Gas Processor and make it to ionize the gases that go through too a energy state as far as you can so you can get these energy levels to put in the cumbustion chamber and ignite them. I suggest to make two of them one for the incoming air and the other for the hho from what every source you choose to get the hho from. Now you can see just how Stanley Meyer ran his 1.6L VW engine on just a 7L/min production rate.
Energy independence is now yours for the taking, enjoy,
h2opower
.Much more info  to follow  Chet
This link courtesy of AAron  K9 Passage of electricity through gases[this link will be fixed Chet]
                   THIS INFO ONCE AGAIN h20 power
                                     The water fuel capacitor is not needed to run a internal combustion engine. The gas processor is the key to Stanley Meyer's invention. In the end Stanley Meyer didn't use a water fuel capacitor with his injectors. The injectors sent in a charged water mist with the same concept as a Taylor cone, primed Oxygen atoms, and recirculated exhaust gases. There was a very little hydrogen produced from the LEDs on the side of the injector to get the reaction started once ignited in the combustion chamber. But with a firestorm type spark plug even that wouldn't be needed, just gotta love addvances in technology .
Example: If the gas processor creates Oxygen striped to it's second ionozation level that newly formed (primed) Oxygen has the energy to break the bonds of water and then react with it. Oxygen in it's second level has 3388 kJ/mol and it only takes 1368 kJ/mol to break the bonds of water, now do the math and you will see why the Gas Processor is the key too Meyer's invention, for you can strip Oxygen way past the 2nd level. Try it, do the math and see the results for youself .
As for using the store brought ionizers not sure but the EEC has to be in the circuit for it consumes the negetive electrons that where just striped from the atom. If the EEC is not put in the nutrual and the negetive electrons will be attracted to each other and your primed gases would be lost in short order. The EEC's job is to consume the negetive electrons so the negetive oxygen ions have nothing to combine with cuting down the probability that the primed gases will combine with anything on their way to the combustion chamber for they will repel each other for most of them will be negetive electrons.
h2opower
              MORE
This is not a hard part of Stanley Meyer's patent to build, and the one thing I want to point out is when Stanley Meyer switched from gas injectors to water injectors the Gas Processor is still apart of the set up, that to me is a sign that it is very important indeed. Even in the Gas Gun again we have the Gas Processor, why no one has ever built one yet is beyond me.
Whats the harm in building one, it's in the patent? If your going to follow Stanley Meyer's work why would you not make one? That's like building a Tesla coil without the spark gap, for all it is a gap in the electrical connection and air. Answer it's in the patent. So, what makes Meyer's patent any different? Build it, test it, and then get understanding if that aproach works best for you, but the bottom line it is in the patent and it is easy.
And remember if I made any mistakes in my math please correct them, for I am only human after all. But also remember any mistakes I made doesn't impair the Gas Processor from working.
The end of the age of oil is now here,
h2opower
an example of a gas processor from h20power
http://www.youtube.com/watch?v=NQvXrxrqshk&feature=channel_page
More information on the Gas Processor see the attatchment for the injectors:
Stanley Meyer: Water Electrolysis -- Canadian Patent # 2067735 -- Water Fule Injection System
Then you will have to find an injector system that you can add in a high positive voltage zone to give the water mist a negetive charge same princable as a Taylor cone or Lord Kevins water battery YouTube - Walter Lewin Makes a Battery out of Cans and Water .
Follow Stanley Meyer on this one, though at this point the whole process became too simple, for he got rid of the WFC, but he kept everyone thinking that he did not, and he started missleading everyone for patent protection purposes. The Gas Gun shows a gas processor that is worth copying.
If you look at the patent and take a good look at the injectors you will notice that he says it is an isolated circuit yet it is bolted right to the head of the engine. The water injectors are not little WFC's they are to give the water molecules a charge, mix all of the need componets(ionized air gases, recirculated exhaust gases, and atomized water mist), and spark ignite it. The whole set up bypasses any vehicals existing fuel system and computer controls, but it is not the only way to get the job done. For what Stanley Meyer was trying to do it worked perfectly.
All three needed items can be delivered seperatly as you have already guessed(atomized water mist, ionized air gases, and recirculated exhuast gases). Then it becomes a trick to find which type of vehicals fuel system works well for this. Now Guass has it also right, you can get the job done with hho, but then you have to make sure that the hho mixture will never back flash for if it does with this much energy content there goes the intake system of the engine, gasous injectors are the safest route to go like that. Not sure how much hho will be needed to, but follow Stanley Meyer's lead and shoot for a pressurized system that maintains the hho at 15 psi or so.
I am for the water mist since that way is simplest and safest. And any water source can be used since it will be the ionized air gases breaking down the water molecules, and not some form of electronlysis. All of the frequency stuff can be found in the patent from 10k-50k Hz and Meyer gives his reasoning. When you let the ionized oxygen atoms break down the water molecule the whole system get very easy, do your homework and you will see .
Well, I hope that helps,
Best Regards,
h2opower.
                                MORE TO COME Chet
Thanks Grandma
