jacob
Guys,
You have to look at this attached pdf file about US patent 119825 issued in... 1871. I found this thanks to a link posted by lynx2000. It is extremely interesting. Here are a few quotes from it:
"My invention relates to the combination of two or more simple or compound helices (coils - i.e.: control coils) and iron cores (collectors) or magnets in such a manner as to produce a constant electric current without the aid of a galvanic battery."
About the collector equivalent:
"The iron core may be a solid bar or a bundle of iron wire (i.e.: multi-strand wire), the latter giving higher tension..."
And guess how we start the power generation process with this setup...
"The mode of producing or starting the action in the helices consist in the use of a steel (i.e.: permanent) or electro-magnet..."
This thing can be started with a magnet!!!! And it is physically identical to the TPU : an outer coil, an inner coil, and a collector. Plus, it is easy to build, so easy to test.
Enjoy!
Jacob
gn0stik
Quote from: supersam on November 01, 2006, 10:57:48 PM
rich,
just lighten up a little, maybe steven told mannix to pull all material from this sight.  heck maybe manix is steven.  who knows?  the facts that he put here are all still here. i'm just sorry you didn't make high priest. jees. lightenup. let's carry on.  it isn't about money for me, that i havn't actually started experimenting it is about knowledge.  however there is still alot of knowledge that people that post here have not experimented with yet, and some of what has already been put here could definitely be dangerous.  especially when given to a bunch of newbies.
lol
sam
Actually sam, he deleted 80% of his posts. I guess you weren't aware of that little tidbit? The only ones he didn't delete are the ones he COULDN'T delete. Most of the reference material we had is gone.. He had over 100 posts when he was here, that he had built up, and now he has only 23 or something silly like that. His last post was a chastisement of us. Now, I don't know if we deserved it, or not. We didn't have all the info that he had, and he didn't share his experimental successes and failures with us, as we did openly, but I understand his anger. And frankly it pisses me off. I could care less if I'm "high priest" as you put it. I care that we preserve the resource that we had, and that we've now pissed away.
jacob
... heck maybe manix is steven.  who knows? ...
lol
sam
Sam,
You smoke too much. Or else it is very potent. :D
Jacob
gn0stik
Quote from: jacob on November 01, 2006, 11:12:50 PM
Guys,
Enjoy!
Jacob
Very interesting find jacob. from the description you gave it sounds quite promising... I'll give it a read.
gn0stik
Point taken sam. There are lots of quotes of SM's original stuff, sure. But it's not the same.
Although I'm not sure what you mean by the connections you are talking about in response to my pointing out what SM said about transformers in phase.. In fact, I'm not sure I've seen the particular connection setup you've mentioned at all. two in series one in parallel, sure. But not three in series first. The best he does in that direction is "or etc."
Here's the quote from SM
It is three separate coils of multi strand copper wire laid one on top of the other, not interleaved. Three is important. You can do many things with three coils. You can run them in parallel, you can run two in series and one in parallel, or etc. You can run a separate frequency into each coil for better control on large power units if need be.
Also, it was more, anger at the loss of any possiblity of future SM letters. Although after talking to Mannix that may not be the case. Although, I wouldn't hold my breath.
Also, I don't believe I said I don't like you. I respect you for what you do. Iron workers amaze me to be frank. you are a rare breed. I just don't think you have much electrical knowlege. That's ok, just watch. Learn, know what you are talking about before posting. You've demonstrated that you don't really even understand the relationship between voltage and current. Again that's ok. Just learn, and watch until you get it... We don't really need a cheerleader here posting nonsense in the mean time.
Nothing personal.
If I didn't like you I wouldn't even regard you. I'd just ignore you.
Rich
