Esa Maunu
Dave,
Maybe you can find some answers from here,
http://tech.groups.yahoo.com/group/nestedfields/
In this group we are studying open systems,that have ability to transfer energy from long distances,and from different time by phase conjugation system.
Esa
Quote from: ctglabs on November 02, 2006, 04:58:19 AM
Virus,
Regarding the Mini-Romag, on my site you can see I once tried to build one, it did not work.
The coils are wired like this so as one magnet induces EMF in a coil, the next coil is wound backwards so it will be powered by the previous coil and now attracted the next one and so on.  Its a kind of rotating field as you say.  But there is no external energy input so it will stop.
As I say, no device can run if it is closed looped.  IT MUST RECEIVE energy from ELSEWHERE.
Perpentum Mobiles are impossible.  Nothing can run without outside energy to run it.
SMs device is a convertor.  You are not going to be able to start a rotating field and pick it up and feed it back to the input.  Its heat losses, etc plus the load alone will shut it down straight away, infact you wont even get that far.
It is a convertor.  It must convert SOME OTHER energy source.  So we can forget about treating it as a perpemtum mobile, as that is impossible.  Free Energy has to do with converting an unknown energy source in to electricity, NOT CREATING energy from thin air, which is impossible even with un-conventional thinking!
Dave.
pese
http://pixerve.de/43323/pese.html
I seen here Patent of Daniel McFarland.
I have same Drawling from Stubbelfield !!
I will find the windings details (not described by Farland
Pese
starcruiser
Quote from: ctglabs on November 03, 2006, 11:58:32 AM
Quote from: -[marco]- on November 03, 2006, 11:55:07 AM
Quote from: starcruiser on November 03, 2006, 10:26:56 AM
Does it do all you would like?
as it runs it runs fine, but sometimes it locks.
i bought it because it wasnt too expensive.
marco
Carl, if you can, get a 2 channel scope, otherwise you cannot do any power measurements or compare phase differences, etc.  Pico do some nice PC interfacing equipment and 4 channel scope too.
http://www.picotech.com/oscilloscope.html
D.
@Dave,
I do have a nice Sencore 2 Channel analog (built in freq counter and DVM) but it has no PC capabilities so I am looking to augment my test gear. Was looking at some B&K generators as well as some PC based stuff, just trying to checkout all possibilities before I commit to buying new gear.
Carl
allcanadian
Hello ctglabs-I was reading your statement
((((When the current stops, the magnetic field collapses on the wire and causes a current that flows in the opposite direction.  Is this not just normal Back EMF?  Since the energy that created the back emf was contained in the magnetic field that was created by the original current flow, then we have nothing more?)))).
This is not really correct and may be part of the problem, when current stops the magnetic field collapses,your scope shows a positive voltage followed by a negative voltage on collapse of the B field but current flow is always in the same direction. If you put a coil in series with a battery and a switch, you close the switch current flows-you open the switch current stops abruptly and the momentum creates an electron pile-up measured as a negative voltage but it is not, the electrons are moving in the same direction they pile-up raising voltage, creating ionization,ADG,and finally VAD or an arc discharge across the switch. Logically you can test this easily, we normally put a blocking diode in parallel with a coil to prevent switch arcing or frying switching transistors, What direction is the diode facing? the diode is letting current flow in series with the coil/transformer in the same direction as it was initially, so if the current supposedly reversed it would have nowhere to go and fry the diode? You can google -electron flow -DC switch arcing -blocking diodes to verify this, it is a common misconception that just seems to go on and on and on, the best thing I think anyone interested in this technology can do is to research (Electron Flow) because 95% of the people I talk to basically believe what modern physics has proven incorrect 60 years ago.
Here is something else to consider in your project, If current flow is always in the same direction- What would happen if you took a piece of wire 1 mile long,started current flowing for an instant then completely disconnected the source? What if the wire was a coil and you applied current only for a millisecond then switched from the source to a seperate load circuit? If current flow is forward and it cannot draw from the source-can or could it draw from a seperate external source? and if the voltage is measured as reversing but the current flow remains in the same direction as physics says it must,does this not seem to be a bit of a paradox?.
Questions are all I have
c0mster
