mrd10
@Dave and Marco,
If I notice something it's worth mentioning. I just noticed with some pics of the 91 volt device, look at some of the pic where it gives you a view of the bottom, and reference this from the top view It looks like the fat wire is tapped out from the centre.
There's just something about this, If it helps to pickup clues, it was worth me mentioning it.
Marco interesting about the thin wire, I can actually see it coming out of the clear pic Lindsay sent us.
I know its hard to see, but its there. So in actual fact this could be underneath the fat wire......hmmm  very interesting
I'm wandering now if this wire is coming from the magnet section.
There seems to be an interation between thin and thick wires. Worth exploring this first.
Good work fellas.
Dom
mrd10
You can see the thin wire where SMs, leg is
Dom
mrd10
Good work comster, at the end of the day, we might bitch and argue, but if we all do our collective bit, it's worth every moment.
I'm a stayer, even after we acheive our goals.
Another year almost over.
Sincerely,
Dom
Mr_Video
Quote from: -[marco]- on November 03, 2006, 06:18:28 PM
Quote from: tao on November 03, 2006, 06:01:33 PM
What if,  just saying what if, the current that is flowing through the collector wires is eddy currents themselves? Is that possible? Could the kicks themselves be eddy currents and this is why steven couldnt solve the heat issues, because if the currents are eddies then he couldnt have the free energy without the generation of heat in the copper collectors.  Just an idea...
i supose so.
i mean not the kicks being eddies but becoming them.
the normal core is being replaced by a multistrand wire.
The heat is not the main problem...
The OU becomes the main problem.
The device in operation is like a bom that can explode evrey second.
if the brakes fail youre gone.
It is certainly not a regular toy.
marco
and like I said before............
we are building it without plans, or even an "Owner's Manual" !!
scotty1
Don't you guy's do any real testing......
I have many many experiments to tell you all these things you are talking about.......
I have been testing a copper wire and needles for the last 3 years..
If you balanced a rotor good then you can easily make the Earth's field turn it, as was posted earlier....it might even speed up a bit!
Then again you could just use a straight piece of copper wire to turn the rotor a little over 1/2 way and let the Earth bring it back....
By using the straight piece of copper wire the rotor will go the same way every time, and the Earth will bring it back every time....if it is balanced good.....
The magnets are everywhere and their numbers are limitless......
Does not Tesla say that sources of radiant energy are throwing off minute particles of matter with great velocity?
Those particles are not the magnets, but the magnets are the ones which are throwing out the minute matter.....some of the magnets cling to the particles and go someplace else......When the orbit of an atom is broken then there is a flash of light, but that atom while "stable" is still giving and receiving the individual n/s pole magnets....they are so small, they can pass through anything....
In the northerh hemisphere the north pole magnets are going down and the south pole magnets going up....in the southern hemisphere it is the opposite, and so it makes a difference to testing......
In a long compass that is hanging in the air and level, you will see that one end is longer...
Hang the 3 foot compass level, then reverse the polarity of the ends...it now lies in a slanted position which can be calculated ect ect....
In the southern hemisphere the south pole of a magnet can lift more filings off the ground than the north pole can....
When my notes are finished you can read all about it and repeat all the tests.....
;D
