AquariuZ
Well that did not take long.
Using one of Cherrymans wheels here another example of a translation of spin onto the wheel under a certain angle.
Optimal position of the wheel in this configuration is around 0 = 0.100 rad which gives a (whopping) jolt of -0.228 rad/s to the wheel.
Again, real world params active. NOT TO SCALE.
Bug or not, with this I can build an accelerating wheel. I will build one now with a three meter wheel.
Cherryman
Quote from: AquariuZ on April 15, 2009, 06:50:29 AM
Dont rush cherryman
With what?
Grinzz...  Well I'm working on two things at the same time...  Not good, i should focus on one.  I had a taught last night about those dumbells (bars) maybe they are not aligned and not only uses as shifting balance but also at the same time as there own lever. But that's becoming difficult 3D Stuff
The other project i post now.. It is not finished, but you cab see the idea behind it. The trick is a steady feedding, and more balls (weights) has to be weighting in a line to keep the feeding on a regular timing.
File attached  (Not working yet, just the concept)
Cherryman
And Aquarius, i see the force you're setup generates.. But still don't understand how you get the ball back up..  Am I missing something here?  ???
AquariuZ
Quote from: Cherryman on April 15, 2009, 06:58:44 AM
You can easily do it using your gear example
