Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
nievesoliveras
@powercat
Just in case and to be all on the same channel. There is another circuit to study and is the one using a 555 IC.
The rotor with the magnets is moved by the 555 frequency and the transistor acting as a relay.
Remember that I am not an electronics man. What I am sharing I learned on the go. I could be wrong.
All the circuits are based on the Bedini's knowledge.
Jesus
pese
Quote from: nievesoliveras on April 18, 2009, 08:32:11 AM
@all
The simplest circuit to understand first is the one with only one coil and a reed switch.
Jesus
the 1n4007 make NO sense.
Only losts of 1 volt !
So the 2000mF Condensor can also onmitted
because the "battery" is an big condensor himself
Pese
nievesoliveras
Quote from: pese on April 18, 2009, 11:02:55 AM
Pese
Thank you @pese !
The time I was experimenting with that circuit, that condenser made the rotor to go faster, I dont know why, and the 1N4007 diode was to make sure the battery was charged. It worked very well. But if you say that it is not needed I will repost a new version without those two parts.
Jesus
Edit********
Here are the promised changes.
Jesus
Goat
Just viewed the 2 following videos
Pulse Coil, Energy Technology Now 001:   http://www.youtube.com/watch?v=r3WxO4CL6bE&feature=channel_page
25w light bulb test on pulse coil technology 001:  http://www.youtube.com/watch?v=0UZFHlfU9Xg&feature=channel_page
This time its a another coil setup than the last one we posted about, as he goes through the setup TR mentioned he would make it open source and post his schematics on his website.
Edit:  Added pic of coil.  Setup is different, he is using the PWM plus a FET driver, diodes are still used to divert to cap.
Paul
pese
Quote from: nievesoliveras on April 18, 2009, 03:56:19 PM
Thank you @pese !
Jesus
Edit********
Jesus
Hi Jesus
the 2 diodes diodes in the bridge are also "directed" in the same way (as the 4007)
so the 3. diode will not help, can onmitted - and so reduce, some losses.
Gustav Pese
