raburgeson
I have a copper nonmagnetic copper core and the only magnetic field generated comes from the inductors. Otto may have showed me my mistake, I was using pulsating dc. My top and bottom collectors were wired like Otto's and my center collector was wraped (opposite) CCW and the sections wired in reverse order. When I saw the wave form I thought it would be as easy as using a zener and a cap to keep it going because it did not run without input. I have something wrong though. The thought has entered my mind that I may have had the coil right and don't know the right way to collect the power in a usable manner. That thought hit a bit late cause I already tore it down to reconfigure it. I am off on the diameter and that might have a lot to do with it so, I'll rebuild it. My collectors are 6" OD without the outside wraps and the inside is 1/2" large. I think if I just keep going through the motions I can blunder into a solution. It may be a tuning like tuning an antenna, size may matter.
c0mster
raburgeson
Lynx2000nl,
   I'm trying to figure out what you're saying I'm not getting it. I'm also trying to figure out if all this circuitry could be hiden it the 6" and nope the 6" powers the resistive load without a special output circuit. Steven walked outside and lit the bulb straight off the coil. We're not sure how it's done yet but the output is pulsating dc with a little ac and I don't think we need diodes. Now this is just an opinion but, I believe if we get it right, the output will be DC made by the kicks. All the work I've done I still can't figure out why the kicks seem to be so frequency locked. I think maybe the output frequency is about the same for all the different types of TPUs. Somewhere I screwed up on mine and I really want to change only 1 thing at a time till I find it but decided to change 2 things on my coils at a time because there is a 100 changes to investigate. This shouldn't be patent sensitive how about Lindsay is the output frequency nearly the same for all of them?
Guys what I'm rolling over in my mind right now are the "control wires". Bandpass? This question is not for Steven or Lindsay, this is a control question and I'm asking the group to puzzle. We know from previous post it's not wise to just single wrap the collector.
Mercedes6
 Zum Posting : Lanca4 und Kator01 vom 2. November:
Schwarze Magie und ?hnliches in diesem Forum?
...So mancher alte Ziegenbock bildet sich ein, er w?re der Teufel.
Um dann festzustellen zu m?ssen, dass er mit diesem leider NUR die H?RNER gemeinsam hat...
Gru? Mercedes
Mannix
Hi all,
can anybody tell me  in what context electron tubes are faster that silicone devices?
comster,nice drawing....short pulses.
Lindsay Mannix
