What does a "kick" look like on an oscilloscope?
Started by Grumpy, April 29, 2009, 09:51:01 AM
IceStorm
@Grumpy
I think if you want to see a kick you should begin with the most simplistic setup, so Tube, build a simple amplifier with only one stage. SM pointed some reference when he talked about Kick so the "Kick" is not a hard thing too see, he stated too that a cold or hot tube make no difference, the kick happen when you open the switch and when you close it.
You need to know who are SM to understand what he is talking about. What he like the most is what he experiment the most and that should be your priority to focus on.
Another thing who is realy important to understand is HOW he found the principle of the TPU. Why he mixed some frequency, what was the first purpose of doing this. 3D sound audio system ? what mean intermodulation distortion to you ?
Best regards,
IceStorm
Edit : i forgot to add something that i think is realy important. Dont get confuse with the 5kHertz DC output SM talked, that dont mean the input is at 5kHertz at all , you can have a input signal of 120hertz and a output at 240hertz or 480hertz or etc etc and in the reverse too , 120hertz in , 60hertz out, frequency doubler/frequency divider. you can sum it too and substract them.
Bruce_TPU
Quote from: IceStorm on May 09, 2009, 06:17:16 PM
@Grumpy
Best regards,
IceStorm
The kick is every time electricity is in a wire.  It is sometimes filtered out, most of the time ignored.  It can only be seen with a Spectrum analyzer.  It grows in Amplitude with the bias.  It is harmonic distortion.  It is everywhere and in everything.
Google it.  Look at it.  Study it.  What causes it?  Hmmm... I wonder.  How can we use it....Hmmm... I wonder.  Gee, let's study it, then move on to photons, or magic pixie dust, or exploding black holes powering the TPU.
Show them and they still don't believe it.  Right in from of their freakin' eyes.
Pisses me off.
Google second harmonic amplitude, harmonic generators, harmonic distortion, intermodulation, EM waves.  EM waves effects on harmonic distortion, white noise, etc.
Grumpy
        -Frank Edwards
turbo
Here is one of the schematics i have been trying.  :)
It's a very simple setup and it involves the iron delay coil and a saturable reactor.
The switch speed of the mosfet >35ns is too slow and the duty cycle of the timing unit is horrible, it stays on too long causing the wasted energy to heat up the reactor not good.
I have tried to tweak it all a bit but it seems to be impossible and that is why i am designing and building a whole new circuit.
You want the initial pulse to be as short as possible and the delay has to be right too, and that is why i have put in the magnetic compression.
This setup is to see the kick ,it does not run in OU mode because the wasted heat and the methode of timing,discharging a cap into a resistor etc, are a all great loss.
Then wrap a copper and the delay coil put it on the output of the reactor and pulse it so you can see the initial pulse and the delayed pulse on the scope.
I'm still quite uncertain if the DC resistance of both coils has to be equal but i think so or at least i am using it that way.
Then when the delay is nicely, hook up a bifilar coil in series with the iron and the copper coil and scope both channels on a dual band scope.
Or use a trifilar coil and just hook up the extra winding to a one channel scope if you do not have a two channel.
The kick shows up on top of the second pulse due to the inductive kickback from the reactor dicharging through the copper and iron coils.
I will post the new circuit whenever it is finished.
Marco.
innovation_station
HERE ARE KICKS THOUSANDS AND THE MASSIVE
CURRENT KICK ...  :P
I DID THIS SOME TIME AGO .... LOL
THIS IS DONE FROM A HALF DEAD AA BATTERY ....
IST
http://www.youtube.com/watch?v=068l0trm6TI&feature=related
I CAN AMP THIS BY INFINITY IF YOU REALLY WANT ....  ;)
LOL
HOW BOUT 10 000 TIMES WILL THAT BE CONSIDERED PROOF ?!?!?!?! LOL
:D
IN THIS PICTURE SHOWEN BELOW IS MY ENTIRE CURCUIT THAT CAUSES THOUSANDS OF KICKS AND A BIG CURRENT KICK ...
;D
1 TRANSISTOR....   8)
