FluxAmps
Yeah welcome comwarrior, so glad to see you here too my man..
I watched all your video's on you tube, following your progress....
Brilliant man, using optocouplers to keep the circuits apart, just brilliant...
You are one of a hand full of people I follow and try to replicate, when it's time to proof
Carry on my man, try and find the right people here and work together(guess u found um already)
I'm still so much in the kindergarten learning process, but it's on places like here on overunity I learn so much
thanks to people like you, one of the real warriors, keep on going my man
I'll cover you!! whenever it would be necessary!
guruji
Hi Gagdetmall can you please explain me this circuit that you had send on another thread especially the FSMR part on the right?
comwarrior
Quote from: FluxAmps on May 29, 2009, 09:43:53 PM
Actially, TBH, the only technical guys i'm in contact with on a regular basis are drevtoobe and pwordcharnoir... Other that those two i got about 5 begginners on my msn list that i'm helping out when they need it...
i guess i annoyed a few people...
gadgetmall
Quote from: guruji on June 14, 2009, 03:54:39 AM
Its My battery swapper . replace  in 220k ohms with a pot to engage the SMALL RELAY to switch battery's for a Perpetual Jt . It simply triggers a relay when a set voltage is reached therefor swapping two battery's once one is charged . Its application can also be used for a bedini if you replace the relay (s)
Gadget
gadgetmall
Quote from: comwarrior on May 25, 2009, 08:40:05 AM
I've allready completed the feed back to source system this weekend...
Update 13 part A http://www.youtube.com/watch?v=Xjeh2qFmWUU
Update 13 part B http://www.youtube.com/watch?v=lDxC7FBrGEk
Welcome My arch Rival ::) What can i say but I told you My feedback to source Works ;) Good work but you are wasting your primary volts with all those parts . what is you input current . ? get it way below 25 Ma and you will have something left to capture and feed back ! The Piggy back works as does the 48 volt fan with a minimal of parts . one thing is use a transistor with high hfe over 200 or a combination of them . you make the trigger to complicated but no one can tell you anything cause you already know it all right .your 5 second claim is ridiculous . anyone can charge a super cap and run their bedini off the bemf STORED for hours !!
Ok I have found something that all of you Ou seekers should try .And those that have tried to replicate My two what i now believe is one of a kind 2 in a million Ou Selfrunners . I really thought you would get it but i guess i am not that good at explaining stuff that i built . I guess i am a natural and see thru things in a different way that most .Try this one
Jonnydavro's no bearing Bedini . You won't believe the power this thing produces with practically less than any of the projects i have completed . this is easier than the 48 volts fan . You will see that there are Numerous sources to feed back . they are all separated generators running from one main magnet . this can run on one milliamp 1 volt and produce big bedini results . My next magnet will be a one inch N48 sphere . i understand the rpm goes higher the 100krps on  a tube magnet . i bet a sphere will go 500krps . the magnetic field is incrediblely large 2 X 2 foot bubble ..
gadget
