The earths mass is being sucked into the sun by the suns gravity
Started by brian334, December 03, 2008, 09:33:40 PM
brian334
Maybe some more proof.
When a particle is accelerated to a high rate of speed and allowed to crash into a wall it appears the particle has more mass than is actually does.
Maybe because the particle is pushing and pulling gravity along with it.
Maybe gravity has mass.
jane36d
Are you saying the sun spite out the planets?
If that is true the sun must have been spinning a lot faster a long time ago.
jane36d
So the rapidly spinning sun spits out a planet with high density and high
angeluler momentum.
Than the sun starts sucking the mass of the planet back in using gravity?
At the same time the sun light from the sun is pushing the planet away from the sun.
So the mass of the planets is decreasing and the volume is increasing allowing the planets to move farther away from the sun.
brian334
The sun spits out the planets than sucks them back in.
The earth spits out people then sucks them back in.
onthecuttingedge2005
Gravity causes objects to 'fall'. the term sucking is incorrect physics.
all things fall according to the curvature of space. it is called a Tensor Field.
