IST'S FURNACE FAN PULSE MOTOR SELF RUNNING NO INPUT BATTERY
Started by innovation_station, September 04, 2009, 08:53:09 AM
innovation_station
FIND 1 OF THEASE ...
almost all the parts required to build a nice unit are in a furnace fan ..
ill add pics as i build it ...
i took the fan apart last night ...
i expect this to be EXTREAMLLY SIMPLE ...
THIS UNIT GETS ITS ENGERY TO RUN FROM THE PUSH YOU YOURSELF INPUT UPON START UP
WHEN YOU SET IT INTO MOTION IT WILL GENERATE ENGERY ... THIS ENGERY WILL BE USED TO ACCELERATE THE UNIT ...  ;)
IST!
innovation_station
here is a pic of the fan i will transform ...
i will have to build the rest of the unit but this is a good starting point ..
ist!
innovation_station
for the rotor i will use ply wood as im all out of plastic ...
and the big peice i do still have is for yet another pulse motor
i will also add 2 10lb cast iron bell bar weights for some torque ...
i will use 1 of my old water turbine units for the weights ..
this can be adjusted easly for more torque ..  simply by adding more weight ..
i may install a stall clutch .. on 1 end of the shaft .. if i do i will want to have enough mass spinning at a good speed b4 the clutch engages ..
and i may run a 12vdc altonator off the clutch ... now that taps mechanical from 1 end of the unit i will also tap mechanical from an old cordless drill motor and a pully sys and a belt off the other end .. just to insure it self starts .. also i will only power 1 motor coil for now ..
and i will on the pulse motor wheel have some collection self run generator coils to charge the big cap that will power the pulse coil .. also there will be a generator wheel .. on the pulse motor ..
but i will start simple for now ...
;D
ist!
1 peice at a time it wont cost cash a dime ...  ;)
innovation_station
OOOO GOODIE ...
I WAS GIVEN ALL THE BIG OLD WIRE SPOOLS I WANT FOR FREE ..
IM A GOING SHOPPING TOMMOROW ...  ;D
NO DIMES!!! :D
THE BIGGEST SPOOLS I CAN GET ARE ALMOST 8' TALL  :o :o :o :o
YIKES ...
just imagine the torque .. on that puppy ... 8)
now i need about 100 more microwaves for all the darn magnets ...
lol  ;)
ist!
pics tommorow ..
there many sizes of spools ..
might even score some big coax!!!
so if all goes well i wont even have to make the wheels ...  ;D
i will add some pics of the drill i will use as a generator .. and what ever else i will need to compleat this unit ...
therealrasta
I am following your idea somewhat.. Need to see and hear more to understand this concept.
