Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
Quote from: ooandioo on June 08, 2005, 09:51:49 AM
Good work, you are first. I'm waiting for answers from supermagnete.de and will go off today to get some steel.
Any idea how we can measure forces. For testing, it would be enough to raw measure N at output rotor and compare it to input. If there is only a little higher out, i will cut a caper...
-- Andi
Input rotor can be driven with cca 5Watts motor. OutputRotor will give cca 120 Watts.
So Let's Push things Foreward.
wizkycho
Quote from: m668004 on June 08, 2005, 11:00:21 AM
@wizkycho
outer diameter: 6,0 cm
inner diameter: 3,2 cm
thickness: 1,0 cm
So they are relatively small, but easy to obtain. I will see, if I get problems.
M.
Think You would have to have very small fingers and very precise equipment to actally make this through
especially adjusting shield. But go on.
ooandioo
Answer from supermagnete.de - they will need some time to calculate the price of such magnets.
Another idea:
If we are not succesfull with our shield we could perhaps use a halbach array. As you see, by arranging magnets you can force the magnetic flux to concentrate on one side. The side "behind" the halbach array would be not magnetic. Suggestions about that?
-- Andi
Light
"Another idea...Suggestions about that?"
- Yes, this IS idea. Good for you. And it might work because of unbalanced forces. Unfortunately ideas with balls and "shields" just a dead way. There's no questions (or discussion) about it.
Here's another very good development of your? thought.
http://ingenrw.narod.ru/Andv2/Opi2.html
just look at pictures.
"Answer from supermagnete.de ..."
- I'm buying from Dura Magnetics. No problem...
wizkycho
Quote from: ooandioo on June 09, 2005, 02:51:28 PM
Another idea:
-- Andi
there is no doubt that shields will work no need complicate it any further.
