gadgetmall
Quote from: guruji on November 07, 2009, 03:36:38 PM
Hi gadgetmall I saw your website very nice best regards. I'm still trying to work out that battery swapper >:( ;D.
So is it possible to use a 12v relay instead of using a 5vrelay than attached to 12v one?
Thanks for your circuits.
Hi . No you still need the 5 v relay but what you do is use the 5 volt relay to control a second 12 volt relay with its own coil supply using the primary source if its 12 volts . In other words use the 5 v relay as a switch to turn on the 12 olt . that swapper is a circuit i made for swapping Very low voltage circuits like a Joule thief that charges another battery . I have improved it with better components for a device i will sell Next Year called the Infinity Cube . Auto switching Light Source that continues to run indefinitely.right now i have a version 2 E-light that has a three position Switch and uses special coils and Fets to light up three 20 milliamp leds and create an Excess Charge of 10 volts 5 Milli ampere all from a 1.2 volt battery drawing 5-10 milliamps adjustable . Other projects are a small retor fit device to put on light bulbs and produce light after the AC to the house light is off . using Tophat Pure white 1 watt leds ,Solar cell and Supercaps and a special JT that runs on 0 .11 milliamps and 0.20 to 2.7 volts .  thanks
Gadget
nvisser
Hi Gadget
I noticed that on your schematic, FushionchipFeedBackToSource002, you use on your bifilar no 16 and 20 wire. Is that 16 and 20 awg?
IT is surely then very thick wire for your drive coil. With 500 turns the resistance must be very low. Is it not difficult to get the input current to under 20mA with these thick wires when you run the rotor or even with the cap switched in to chance it to solid state?
You also mentioned somewhere that the Hfe of the transistor should be high. I checked the gains of the transistor that Bedini uses and they are low.
I am currently switching the positive and uses a 2sb1375 pnp with a gain of  320 where the 2n3055 that is used by everybody only has a Hfe of 20
The circuit for using a pnp are nearly the same. You only swop the 2 battery polarities and the 2 diode polarities. Your charge diode and the diode on the base.
The only thing I still have to do is to turn a new bifilar coil with this thick wires.
Can that be the secret to your setup?
gadgetmall
Quote from: nvisser on November 08, 2009, 03:43:14 AM
Hi Gadget
Hi i am not sure but i use thick wires . The secret on My piggy back coil system is to extend the main coils Core to allow many coils to slip over that core . Lots of energy from the back of My coil . I could probably put a foot of welding rods sticking out the back of my main coil and hang 10 coils off the back ,each producing its own volts all without and Lenz law affect to the main rotor !!This is one way i have achieved a self running Over the unity bedini . Dont listen to what Bedini says . Its to throw us off . I things like feedback from the secondary directly to the primary source . He says it cant be done with SG replication . I say and a handful of others thats not true. Transistor Amplification and switching times are important in some other fan Bedinis i have built .
gadget
Maqone
is dhis run?
Dimensions: 203×50×48 mm
Supply voltage app: 48 V dc
Power consumption: 7 W
Capacity: 75 m³/h
Bearing: Ball
Sound pressure level: 48 dBA
Pressure: ≤62 Pa
Type tech: Tangential
Rotational speed: 4300 r/min
