The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
nievesoliveras
Paul-R
Quote from: markdansie on December 18, 2009, 04:13:55 PM
So where is a one watt device?????
I have told you once. I shall not tell you again.
markdansie
@Chris C and all,
Please have a great Xmas and new year and I look for another exciting year next year.
I am sure Lee-Tseung will provide us with a few laughs (like a comic strip), and many more fun things will surface to investigate. I am sure another Mylow will surface (although Steorn are doing a good job as a fill in act)
There is some good stuff happenning in some of the other threads.
Thank you Pirate , Jeanna and the many other regular contributors.
Finally , thanks to our host Stephan.
Wish you happiness and a good holiday
Mark
ltseung888
Another Input Voltage and Current Waveform picture
This picture shows the Input Voltage and Current synchronized.  It is essentially Voltage and Current against Time.  We can derive the Power against Time curve as Power = Voltage x Current.  The shape should also be somewhat rectangular peaks.  The Input Energy over Time interval t1 is the area inside the peaks over that interval t1.
There were some previous discussions on whether the Input Voltage should be the battery voltage of 12 Volts or the RMS value.  It is clear that the RMS value should be used.  Experimentally, the voltmeter should be placed in position B as shown.
Merry Christmas to you all
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
ltseung888
The Swapping Battery Test
We have now tuned the Wheel so that the DC Voltage Output at no load was over 24 Volts.  This can indeed recharge a 12V battery or two 6V batteries.  The recharging is successful.  We shall be doing the swapping test in the next few days.
The test will involve the following:
1.   Start with a fully charged battery A (e.g. 12.55V) and a somewhat drained battery B(e.g. 12.00V).
2.   A is connected to the Drive Coils and B is recharged via the Collector Coils.
3.   B can be rapidly recharged to over 12.55V while A drops to around 12.00V in less than 5 minutes.
4.   A 3watt lamp can be turned on from time to time when we find the recharging is too fast.  The recharging time slows down.
5.   We can put digital voltmeters on both batteries to check their voltages simultaneously at all times.
6.   The role of A and B are then swapped.
7.   Kenneth Chong is designing a more automatic procedure so that we do not need to keep doing the manual swapping (of clipping and unclipping wires).
We shall have the video and the results after a few hundred swaps.  If the batteries retain their charge and the 3watt lamp can be on for a few hours, we can conclusively demonstrate Overunity in a different way.  Our entry to the overunity.com competition will be technically more solid.  We plan this as a Christmas Gift to the technical people of the World.
