Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
agentgates
Quote from: hartiberlin on January 06, 2010, 06:04:13 PM
The question is, where the zero line is at and what kind of DC
level do we expect ?
Is the zero ground line where the left red maker is at ?
Yes, the zero line is arrow on the left side. See the scope shot I recently sent. I changed the indicator on the right, so now it shows the correct value.
Quote from: hartiberlin on January 06, 2010, 06:04:13 PMIs that the input current or input voltage ?
Ignore that ~11V, that is average and the off state is also calculated.
UPDATE
Appologize Gentleman. I think I must sleep a few hours as I can't keep my eyes open. I'll be bcak tomorrow.
Take care and keep saving everything and keep me up-to-date with your stories on experiments. :)
Bruce_TPU
Tony,
Aside from your melted IGBT's, is your current coil producing more power out on the secondary than is put into the primary?
What is the input amps and volts, and what is the output amps and volts.  What is the load on the output?
We know that you are tired.  We look forward to seeing a circuit and video as well when you are able.  Thank you for your hard work!
Cheers,
Bruce
Mannix
I think tony is seeing massive heat buildup on the pn junctions and the effect of what can only be  high current of some strange kind.
Best to build one and see this for our selves.
It sure looks like there is spin happening there , harvesting it in phase will be the challenge.
I will try it with bottles as soon as i have zapped a few fets.
this is not a complicated bulid .
I remain fully optomistic
cristachelu
Sorry to interrupt you but I think the coil has to small inductance and the pulse needs to be very short to lower the switch heat.
Maybe a HV capacitor discharged through a gap in a resonant LC primary maybe...
Mannix
Quote from: cristachelu on January 06, 2010, 08:50:08 PM
Sorry to interrupt you but I think the A has to small inductance and the pulse needs to be very short to lower the switch heat.
That sure would lower the component count and the pn junction  would not be able to suck the particles away.
so a low current hv supply with a little spark gap  no oscillators at all hmm...
I imagine it would make a buzzing sound and have possibly vibration, lots to try here
