Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
ramset
 :o :o :o
I love big spikes!!
Carry a big stick!!
Alex ,
you have to be scaring the heck out of those electrons.
Maybe now you'll get there attention ;D ;D ;D
Sweet
Chet
Thanks Grandma
Groundloop
Chet,
I think there is a direct relationship between the high voltage
spikes and the high voltage output in my generator coil. If I
clamp the coils with a diode then all the output voltage is gone.
Do I dare to remove the diode over the collector and emitter to
see what big negative spikes will do with the output? :-)
Alex.
synchro1
Quote from: Groundloop on January 07, 2010, 01:08:34 AM
Oc,
Thanks for the added information about the Orbo motor system.
In this thread we are trying to make a solid state version. So some of your points will not apply.
But good information anyway. One factor for the solid state will be the frequency. Higher frequency
will give out more power. This is compatible to RPM in a rotor, I guess. One other factor in a solid
state system is resonance in the input toroid cores. This will lower the input usage to almost
nothing while at the same time switch the magnetic field on and off in the A coil.
So there is a lot to research.
Alex.
Two twin toroid inductors in resonance switching the magnetic field on and off in the A coil, lowering input to practically nothing. Awesome! Don't forget that the natural oscillating frequency of magnetism was estimated to be around 159KHz according to Hans Coler, demonstrator of the Strumzueger. Imagine two variable capacitors, hemi tuners, in adjacency. A powerful variable inductor nearby, regulating the resistance between the variable caps. One cap in series with the toroid's and the other in series with the A coil. This describes the kind of feedback loop Coler's Strumzueger used.
Bruce_TPU
Hi Alex,
Last night I lay in bed thinking of this device we are working on and I thought of a easy test that would POSSIBLY allow us to use the other side of the toroid to produce additional power.  When you first see my picture, before you dismiss it, there should be enough of an oscillation of the flux on that side to produce something.  Even if it is a little, an additional generator coil could be placed on the backsides of all toroid.  Anything produced is "FREE" because the toroid doesn't know it is there and the back side is only being used as a gate anyway...  ;)  Of course, it may produce nothing, but I think it will produce something though not much!  Just place a coil over the two magnets and place on the toroid.  Add one additional magnet, opposite polarity as you have already deduced on the far side of the coil.  pulse and see what you see.
Cheers,
Bruce
Groundloop
Bruce,
Of all the crappy ideas,..............Just kidding LOL
I tested your idea. I made just a little coil onto a Ferrite tube and put the
new coil as in your drawing. And.................I worked! :-)
The generator coil did give out the same voltage as before and
the new coil was an added bonus. So now we know, three coils
on a setup like this.
Thanks,
Alex.
