Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
happyfunball
If the YOG is overunity, then a powered switching device for the magnet shouldnt be an issue. Assuming the YOG will drive a generator/ electric motor, it would be a simple matter of using a stored charge (rechargeable battery) for the first few passes until the YOG can generate power, which would then recharge the battery. Basically the same as a car's ignition. Right?
WattBuilder
Quote from: ragnew on January 19, 2010, 11:30:08 AM
I really like what you have done so far.
Question:
Any luck on making the magnet flip on its own when the arm reaches one side or another?
Thanks Ragew,
I have all the parts here now ready to go ….  but I have decided to put a hold on the project for now. The reason why I decided to do this is because even if I built this there will be still doubt.
At this point it all comes down to the array.
@El-Tigre,
Great work your doing their !
The array will try to twist the wind vane and you may run into alignment issues like I have but there is a way to over come this.
Have your drive magnet face north into the array and also have your array in the shape of “ U “ upside down. Just picture my array with walls on the side.
One other thing if you slightly tilt it forward or back you can control the direction of turn.
Quote from: happyfunball on January 19, 2010, 05:48:05 PM
@Happyfunball,
Your right. If you look back to Broli’s picture on this thread you will see a picture of many YOG’s in front of each other lined up. When you have them in a modular array like that, you will get an OU Engine. Just picture the turbine shaft longer to reach all the YOG’s with one-way sprockets.
@ ALL
My claim still stands on it’s own merit.
This Video is conclusive proof I have achieved OU.
Video: The Yu Effect â€" proof of energy gain from magnets
http://www.youtube.com/watch?v=iBtl0OTSccs
Howard
WattBuilder
To ALL Moderators,
Shouldn’t this video be great news and the topic be posted on the forum’s homepage news list ?
Here are the grounds to post it.
1.   I have achieved Overunity.
2.   I have proved The Yu Oscillating Generator can harness energy from magnets.
3.   All Inventors and researchers working towards energy from magnets now have more merit and they are not all crazy.
4.   I am the first to “Publicly prove energy gain from magnets”. Simply because there is no data available measuring In vs. Out with a meter publicly. (No hands)
5.   Most importantly !  Lives can be saved.
Posting this as news would advance further peer review.
My claim still stands on it’s own.
Howard
mr_bojangles
theoretically your input should be the difference in weight of the lever plus friction
your video does not prove anything, your starting point is higher than the point you are gathering your output from, your output meter should be at the same height and degree that you start the lever at
your starting the weight at like 60* and letting it fall almost 150*
and since your lever is top heavy the only gain you can claim is the distance the magnets start until the lever is upright and slightly past the 90* mark, because anything past that is gravity which is where you are getting your force,
changing it and making it top heavy most likely makes it more inefficient
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
WattBuilder
Mr Bojangles,
It looks like you did not bother to read my post to you. The lever weighs 0.1 Pounds for the experiment. Think it over again. You will find that when you drop something that weighs 0.1 pounds from 8 feet 3 inches “ which is the height from the middle of my array to the floor”.
You won’t even get close to 1.3 pounds by far.
It’s common sense right ?    ???
Howard
