What if a magnet IS a generator?
Started by akjones, January 06, 2010, 11:43:37 AM
BobTEW
Whoa,just a minute! I come in hinting and "bluedemon" come in teaching.   Great job! We have already some of the same ideas. I think you are on the right track.
I been searching magnetic anomalies for two decades, because of idea of a "series" connection. Magnets are "bulk additive" when two domains join together they are stronger; the attractive force.
Now the "parallel" side of the magnet is descibed by bluedemon.
Found this picture on the net of how I think the force looks to me.
http://images.google.com/url?q=http://dsd.lbl.gov/ImgLib/COLLECTIONS/BERKELEY-LAB/RESEARCH-1991-PRESENT/index/96703308.html&ei=jD1oS8uLPJLUsAP5v5n_BA&sa=X&oi=unauthorizedredirect&ct=targetlink&ust=1265124500986964&usg=AFQjCNG6hVnRqwGH-8hXtmHoBCSFlO6qKQ
stevensrd1
Ive personally wondered, you know how wire in coils, say used as a pickup coil for a passing magnet, to generate electricity,,well the wire used is not magnetic, but what if the wire itself was made of a metal that would stick to a magnet. so then we have a coil of wire, that itself a magnet would stick to. Now that coil would not need a piece of metal or iron core in the middle as most coils do. It --itself would be its own so to speak iron inner core, and what if as power runs through that coil, with the wire itself being magnetic, would that increase the energy by some chance, perhaps, just a thought!
FatBird
Watch this video & you can see the Plasma Spinning clockwise or counter clockwise depending on the magnet side:
http://www.youtube.com/watch?v=3grPo81fBrA
gmeast
Quote from: akjones on January 06, 2010, 11:43:37 AM
Could we be missing the forest for the trees?  Electrical current running through a conductor produces a magnetic field.  A magnet has a magnetic field.  How do we know that the magnet itself does not contain a toroidal flow of electrons (a circuit in other words) perpendicular to the poles?
If it's true, then a magnet is a room-temperature superconductor (at least for that circuit) because it does not generate heat - which may begin to explain the relationship between magnets and superconductors.
The question is how to measure/tap into the circuit?  Can anyone think of a way to magnetize a coil of iron with a measuring device (or even light bulb) in place in the alleged circuit?  Maybe loop out part of the materal, kind of like a figure 8 shape but a smaller protuding loop?  Insert other materials as a gap?
Is this idea worth baking further?
Our spiritually inspired savior Joseph Newman claims that if you take a "C" magnet and place a flat coil in between the poles that it will generate 'power'.  He can prove it ... just ask him, and if you kindly ask him for a scientific explanation, he tells you "because I say so" and then calls you an idiot .. but it works he says.
twinbeard
Quote from: FatBird on September 22, 2010, 02:53:58 PM
This qualifies as the coolest thing I have seen today.  Thank you for linking to it!
Cheers,
Twinbeard
