Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Bruce_TPU
Hello ALL,
AHH...the sweet victory of a small success...LOL  Bar is hard as a rock!  And I have already machined it down.  I have a before and after picture for you all.  Sands up real nice.  It did take a few more drops of hardener, but the trick was in mixing the ingredients in the afore mentioned order!
My first Nanoparticle bar is complete and a success!  PLEASE remember, it has a TOTAL surface area of OVER 30,000 square feet!!!  ;D :D ;)
Time to make more....  ;)  I will video it...LOL  It is fun but messy!
Cheers,
Bruce
http://www.energyfreedomreport.com
gravityblock
That looks very professional Bruce.  Great Job.
GB
haithar
Naudins experiments on a solid state system have no significance unless data on input parameters (current, voltage, duty cycle) are provided, same for the output.
What's special about a system that transforms energy between inductances, even if it only works with magnets? It's not interesting until power output exceeds or is equal to power input.
Bruce_TPU
Hello ALL,
You will want to check out the latest from JLN Labs.  Now he is using a nanoperm core...!
Click the link and scroll down the newest part!
http://jnaudin.free.fr/2SGen/indexen.htm#moving
Tonight I completed another 4" nanoparticle flux bar and a 1" bar.  Video'd it, I just need to splice with some new software I bought.  Tomorrow I will sand and file them.
Cheers,
Bruce
stprue
Quote from: Bruce_TPU on February 18, 2010, 08:28:04 PM
Hello ALL,
Cheers,
Bruce
WOW Bruce the bar came out great looking!  I can't wait to see what it can do!  Also thanks for posting the updated info JLN link
