Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
synchro1
@Mags,
          Can you post a schematic of your BEMF recovery circuit?
Thanks.
Magluvin
Syncro
here ya go. I just did it in paint. =]
Mags
Edit   the + on the cap is on the wrong side, sorry.  =]   read the next post also.
Magluvin
Hey Sychro
Correction. The + mark on the cap is wrong. =]
The cap is charged out of phase with the PS. But adding the pickup coil output works because it is electrically isolated from the rest of the circuit. Sorry bout the error there. Im beat, been up since yesterday playing with this stuff.
Im on to something a lil bit different but kind of the same. As ideas come from all these experiences, and more understanding of what is going on. This Idea is seeded from the experiments that I did this morning on ITS's magnet in the transformer gig that I had to try but put to rest fairly quickly. It was an easy project. But that stiffening of the cores field flexibility by the magnet led me to some good ideas of what can be going on in the cores, and Im mixing that with orbon. We will see in a couple hours.
mags sleepy ideas    Maybe Im dreaming   =]
Bruce_TPU
Hello All,
I have made some progress this evening.  ;D
Going with my steel bolt idea, what I did, was purchase several 1"x6" by 1/8" steel plates.  At first I tried the Flynn Parallel path and it does not work for this application, at least not with a toroid that does not fully saturate.  I have received my NEW toroid in, but have not yet wound it.  I will keep working on bumping power output, until I can go no further, and then try a saturating toroid and a switching circuit.  This is real current, not just a reading with no power behind it.  Even though it is very little, keep in mind what I am doing.  Optimizing!  If I can eventually barely spin the rotor and can produce 12 volts and some current, imagine what should happen when I switch it very fast with an electronic circuit.
So, what worked tonight was taking last nights set up, of inserting the toroid with a magnet in the center of it.  With a small 1" bar magnet on the face of the toroid, with the NORTH up (works way better!) Then I place three of the steel plates sticking straight up, from the top of the magnet.  I am now up to 3.9 volts output!
Cheers,
Bruce
http://www.energyfreedomreport.com
Bruce_TPU
Hello again,
What can I say, but WOW!  Set up is identical as above, but now, I have added a SECOND LED (7000 mcd from Radio Shack-both) in series with the first, changing the positive and negative sides of the LED from what I did have....New Output Voltage ------> 5.6 Volts  Both LED's Brightly lit.  I have NO idea why the voltage increased to the load... kinda freaky! hehehe
Tomorrow I purchase some more of these special LED's.  But now, I have some more ideas to test and coils to add.  By the way, the output Frequency is aprox 138 Hz.
Cheers,
Bruce
