Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Omega_0
Quote from: lumen on March 10, 2010, 08:27:57 AM
Why would the flux leaving the core during the coil on time be such a problem?
Let me clear it. Flux should leave the core at on time, it is not a problem.
Now how much flux should couple with the pickup and how much should remain ? This is the question. Ideally, one would want all of the flux to leave the core and couple with the pickup windings, not only half of it, to induce max power.
I'm sorry, I could not come up with any clever ideas on this today (except the one for placing the core such that the hole faces the PM instead of edge on).
Perhaps the best designs are those posted very early in the bigger steorn thread.
gravityblock
Quote from: exnihiloest on March 10, 2010, 04:23:23 AM
Your reply is the proof that you, not me, is bothered with cooling. You spoke the first, not me, about cooling in this thread.
For me there is no cooling so I'm not bothered!
If I detect one in the future, I will inform you.  ;)
Bruce spoke first about the cooling effect in this thread, not me.  Why would I be bothered with the cooling, when I think it's a good effect?  You on the other hand believe there is no cooling, so you are bothered with these reports because it is in disagreement with what you believe and it would be an indicator of excess energy in this setup, which you are also against.
GB
gravityblock
It doesn't matter if the flux leaves the core or doesn't leave the core at on time, because the pickup coil is open circuit during the on-time of the pulse, thus if there is flux leakage due to saturation during the on-time, it's not inducing an EMF in the pickup coil.
GB
gravityblock
I wonder what the results would be with partially demagnetized magnets.  Steorn's patented measuring device mentions the testing of partially demagnetized magnets.
GB
Bruce_TPU
Good evening ALL,
I found what I hope will be the perfect form for my first bias experiment.  It is plastic.  Later I will try the metal.
Now it is time to wind it, with three layers.
Cheers,
Bruce
