Mk1
@all
I am not sure at all about the no iron soft that is .
I learned about the cook coil , it basically is a isolated soft iron coil connected to nothing , it will repulse a magnet .
After many studies made by Jeff Cook , he discovered that pulsing the coil with a 9 volt battery it would induce a strong rotational field that i believe could be captured by coil arrangements.
Please look at it ...
Also the vibration of the tpu i will say it , there is got to be a moving part , like a magnet in ferofuide , putting a magnet on top of it like SM dose would induce a rotation in the magnet it self .
Anyway keep the good work ...
http://www.jeffreyncook.com/jeff%20cook%20effect/jeff%20cook%20coil.htm
giantkiller
giantkiller
giantkiller
Air led with resonance! Whoop! There it is!
http://www.youtube.com/watch?v=k0dMMEZW7M0
Still using Tesla bifilar pancake coil as transmitter.
--gk.
wattsup
@GK
Thanks for your good video and showing the effect. There is so much more to show and learn about this way of seeing coils/pulsing/interactions always with effort to link these effects with clues for TPU workings.
From the many coil winds and effects seen, from the fact that SMs center toroid has two different wire pairs, the fact that the toroids in the LTPU showed the greatest amperage readings, that the FTPU had the same Toroid and only went up to 60 vdc.
In my video I show a simple bucking coil that can impart via air to other coils and pick-up energy, but relatively speaking, my pulse generator does not have any real power to send into these coils. But the effect still speaks for itself.
What I have learned among many things.
The bucking coil is the tool. I will now use my recent new toroid that has bucking coil secondary wound first, then bucking coil primary on top. When I pulse the primary, I still get the air transfer, plus now, I can send all the secondary back to source, plus all the primary flyback, again back to source.
This is the answer. A wind mill that makes its own wind. That's why the center toroid in the LTPU had the highest amperage readings, because the primary was being pulsed higher and higher and the secondary was being sent back to the same growing source.
We should not even care about putting on any load. We should be more concerned with mastering pulse primary, send secondary back to source and perfect this to the point of unity. Then you add a primary in series with the first one and continue from there.
To ride your car, it first has to run at idle before you can step on the gas. This is what Tesla has been trying to tell us. Run unity, then attack. If you are always more concerned about the juice going to load, how can you work out overunity if what will help you achieve it is burned up right from the start.
Anyways, let me expand on what I think is happening when he says there is no mass circuitry in his device, he does not need it at all. All he needs is the following.
Once, way back I made a replication of the ambient energy device. It was a circuit with lots of diodes and caps that I connected one long wire from outside my house, to the circuit and it produced some 1.5 - 2 volts dc.
OK, you take that circuit and put two rings in series then to the circuit. That is your ambient energy catching device and we already know it works. Yes but there is not enough ambient energy to catch if the wire is not running outside the house. That is very true when you are waiting for the long long wire to catch ambient energy. But what if instead of waiting for the ambient energy, you make your own ambient energy pulse through the center toroid. So you pulse a primary and return the secondary back to source, but at the same time the primary produces the ambient energy that you want to catch instead of hunting the open space. You produce concentrated ambient energy that the circuit, via the rings, is more then willing to suck up.
So as for no mass circuitry, would an ambient sucker circuit plus a small pulsing circuit be considered mass circuitry. It would depend on what SMs degree of mass circuitry would be, but in my book, I would say no.
Do you understand what I am trying to say. lol
Shit. Next build coming up and video soon enough.
