Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
Rapadura
It seems that 2010 is THE year of free energy!
helmut
Quote from: haithar on April 25, 2010, 05:49:29 AM
Nice, but 40 seconds don't allow for much euphoria yet. I'm eager for more tests.
Muss ich mich fürs deutsche Forum extra anmelden?
Ja,macht Sinn   www.overunity.de
helmut
mscoffman
Comment from you-tube:
>ke4uyp: It Is scientifically impossible to produce more energy than you
>consume. If it were possible to produce more energy than you consume
>then you could disconnect the source of input energy, and feed the
>output back into the input and it would run indefinitely. Perpetual
>Motion, obviously your measuring equipment is not up to the job because
>of your test results
Me:
This HHO production mechanism is good thing. It is
potentially a *fueled process* as natural water contains
deuterium an isotope of hydrogen. You can either pull
the deuterium out via a chemical process and burn it in
an ITER large scale fusion reactor or use it a little at time
via as a CF Cold Fusion process. So there is *nothing* in
the manufacture of HHO that *requires* it to be theoretical
overunity ZPE. This is only an overunity process because
scientist don’t currently fully admit to what is happening.
But they are slowly coming around.
Don't forget this self running system contains a 33% = 1/3
efficient Carnot' gas heat engine. If it self-runs the 3x energy
gain has got to come from somewhere. This is different then
potentially self-running on a small amount of rotoverter gain.
:S:MarkSCoffman
haithar
I'd have waited with a comment like that because you have no indication that is does self run. The energy contained in the system is more than enough to act as a buffer in the short 40 seconds to run electrolysis and the motor.
Technically you don't need any/much fuel if you consider the fact that you get water from the exhaust.
