happyfunball
There's a very simple way to determine if Orbo is OU.
Is Steorn's headquarters in Ireland powered by Orbo technology?
Bruce_TPU
Quote from: Omnibus on June 18, 2010, 11:38:43 AM
This is not only not stupid but this is exactly what should be done at once. That would be the ultimate proof that we have OU. For this reason someone knowledgeable in designing and making converters should make one and we will probably have a self-sustaining device.
Hi Omnibus,
Very interesting detective work thus far.  I am VERY interested in the "magic air core" primary.  Therein seems to lie the magic.  A picture or two of it in it's dissassembled state, as well as your "surgery" using perhaps powerful magnifying glasses, to see how this coil is wound.  Also, what awg wire is it wound with?
I do like Broli's suggestion, as it cuts to the heart of the matter.  2.6 cop is sufficient to do something with, to make the OU self evident to all.  How you proceed from here may very well be an important step, as you well know.
Cheers,
Bruce
Omnibus
@Bruce_TPU,
I thought of posting pics of the disassembled transformer but it all came out very messy and I thought I might postpone it. Will see what I can do tomorrow. Also, the surgical work still meets dead-end but I got a few more of these transformers today. I could also find 100pF caps and will post results with these in parallel with the coil. The capacitance issue is the most serious so far. As for @broli's suggestion, that indeed is the ultimate but a good electronic designer is needed to take care of the converter. There was someone with a handle @poynt99 in the village of the banned forum who modeled Steorn's scope traces with electronic elements. I wonder if you remember him. His traces came out of almost exactly the same shape as Steorn's. It would be great if he could help in this case but I'm not sure he reads this forum.
rensseak
Quote from: happyfunball on June 18, 2010, 01:14:07 PM
Maybe not yet but in the future? That is only the beginning.
And what progress do your experiments?
Omnibus
@Bruce_TPU,
Here's a pic of the air coil. Will be posting more data in a bit.
