bolt
Quote from: SkyWatcher123 on August 08, 2010, 12:19:16 AM
Hi bolt, those are interesting thoughts. I was a couple days ago just thinking about bifilar coil and why could we not somehow induce energy into another coil from the interplay of the so called canceling fields, though it sure sounds like your saying the fields under a certain condition can generate power for us. That rings true to me.
peace love light
Tyson
It already does as Joule Thief uses biifilar to CANCEL magnetic field so the in phase power is trashed into VARS. Now you have kinetic energy field as electrostatic and volts goes UP. How do you think JT get 50 volts from 5 without a transformer and its not electromagnetic. That is Hertizian leads to loss you need longitudinal. Now you see the JT is actually making a tiny weak NEGATIVE inductor where power of the sense we want flows back INTO it and NOT out. But only if you understand this and make it properly.
Oh also note with JT as really simple concept has missing field? There is no interaction layer of two electrostatic X Y components as within the Don Smith, TPU and Kapandze. You need a relative field otherwise the earth with provide a weak X one and give weak results.
SkyWatcher123
Hi bolt, thanks for more explanation, though I'm no not so great at visualizing things with words. Could you possibly make drawings or diagram of some kind to help explain your ideas better to me, maybe it could help others understand better as well, thanks very much.
peace love light
Tyson :)
stprue
Quote from: giantkiller on August 05, 2010, 10:27:28 PM
Here ya go pretty coils straight from the bedside: go to downloads and look for gk1-gk27
http://www.overunity.com/index.php?action=downloads;sa=downfile&id=406
You still have to work.
The big chips are 'break before make' when the address lines change. Try a JK flipflop with the !Q tied to CLR then clock it. Very high speed. That is the big secret. Floating ground, floating fets(IRF840), low current, controls all the way around(snake biting its tail).
The fet driver chip is a p605. The clock chip could be a 4 bit binary out. Look at the truth table. 1 line then 2 lines are on at the same time then 1 line.
There is also a funny looking switch in the circuit. I have used a fet. It is in the feedback loop internal to the ckt itself.
All cmos for 9v bat operation in center.
Notice no caps on the coils? That is where we come in and what about the magamp? Iron centers. Color picture posted previous. I have this build 80% done. I prototype now.
Rat shack arent plated anymore.
I got mine from http://stores.sacelec.com/sacramentoelectronics/ search for wh22-
Look at the TPU this way:
All who know are under NDAs. How do they get it out? Recruit somebody who has a clue, who can be shown with out mentioning vital terms and then the recruit takes it from there. Might the recruit be you?
Could be my last build. I am not saying anybody has to follow. I just give
Hello GK can you post this description and pictures here before the trolls push this post back 10 pages?  Some of us don't have access to to view the downloads.
Thanks...Stew
sigma16
Quote from: giantkiller on August 07, 2010, 11:05:35 PM
This sounds like a stun gun to the secondary of an ignition coil if the 2kv does have current. Maintain the outer spark gap of the gun. oops. The ignition coil is not air core though. Could use a ratshack spool? Stacked 4 high to get the turns.
From a practical perspective, the stun gun is too much.  Your typical coil can't handle that much voltage, and the only easily obtainable switch is a spark gap.
Drive a flyback or even an ignition transformer and get a few KV, hv bridge of diodes and cap bank to get HV DC.  Small neon transformer or HV DC converters work great as you only need a few mA.
The drive section can have a ferromagnetic core.  It's just producing HV.
Ratshack wire is enamel coated and will arc through.  HT mag wire or other HV rated wire.
Oh, and ignore "bolt", he doesn't know what he is talking about.
giantkiller
@stprue,
Show a file sharing site and i will put them there. The files are in the range of 500k.
Of course you don't have access to the downloads. Your attention is kept on advertisements and useless hyperlinks.
Guess that is an indication to move or go away.
I would even put them on Wattsup's ftp if i get access. I don't have a problem with doing any of this.
@Bolt, Sigma16,
I see both sets of design specs and both are valid. If I have to play referee I will. :D
The choice of approaches just depends on the level of shockwave one wants to play with. So I am not nor ever choosing sides. But if we are to find the designs that perpetually run a cell phone or battlecruiser we must entertain all the aspects of the process whether they are in a button cell or meld matter. We have seen these and the full gamut in between. All one has to do is see the prospect or pick a level to work in. If you like watching sparks jump into your pc then knock yourself out(that too will eventually happen :o) or if you believe it can happen across a substrate level at the subatomic layer then go for it.
The larger effect production takes a certain type of material(Simg16) whereas the smaller effect takes a certain level of configuration(Bolt).
@Sigma16,
I can order the wire and do that with a NST too.
@Bolt,
The ECD is a 2 phase Wye or yagi configuration. This means 3 snakes biting the others tails at 3 places in the ring. I have a ring configuration of this happening at 1 place on the ring. 1 place. I can continue this build knowing full well that when it is done all I would have to do is split the full control windings in 2 more places to achieve the yagi configuration of the ring. Not a big deal to do.
