bolt
Just take 3 inductors even 3 large mains transformer wired in WYE  and wire as my FET driver. Tune the caps to overall frequency to suit your coils and when you hit the magic spot the reactive power and volts will FLY!!! Amps drop down to almost nothing at 12 volts i be surprised if you hit 100mA. Measure the volts and amps going round the coils! Freaky:)
Now you got a rotary 3 phase electrostatic field that creates all kinds of weird effects. Anyone thinks this is hogwash not paying attention in class. This is a basic building block to many many OU devices.
Go and watch Eric Dollard Ham Radio conference if you not seen.
http://www.youtube.com/watch?v=YhuSn6sc7sc
giantkiller
Quote$ 13 4.9999999999999996E-6 30.13683688681966 49 5.0 54
T 240 224 272 240 0 4.0 1.0 0.1247616687560119 -0.08025312348361974 0.999
T 320 224 352 224 0 4.0 1.0 -0.5603558067052512 0.5164885116133933 0.999
w 320 224 272 256 0
w 272 224 320 256 0
d 448 256 448 320 1 0.805904783
l 496 176 560 240 0 1.0 -0.03638582839176202
l 624 176 560 240 0 1.0 0.018827952851354326
l 560 240 560 320 0 1.0 -0.017557875540407695
c 624 176 624 320 0 4.9999999999999996E-6 32.56733914306682
w 624 320 560 320 0
w 352 256 448 256 0
w 448 320 560 320 0
r 96 224 160 224 0 10.0
w 48 256 80 256 0
w 80 256 240 256 0
w 160 224 240 224 0
w 352 224 384 224 0
w 384 224 384 288 0
w 384 288 272 288 0
w 272 288 272 256 0
w 496 176 496 224 0
w 496 224 384 224 0
v 160 144 192 144 0 1 60.0 5.0 0.0 0.0 0.5
w 192 144 272 144 0
w 160 320 448 320 0
x 20 307 83 313 0 24 12vdc
w 272 144 272 224 0
w 160 144 160 320 0
v 48 256 48 192 0 0 40.0 5.0 0.0 0.0 0.5
w 48 192 80 192 0
p 624 176 624 320 0
p 640 176 640 320 0
w 640 176 624 176 0
w 640 320 624 320 0
174 80 192 80 256 0 1000.0 0.0347 Resistance
x 166 101 190 107 0 24 5v
x 254 2 306 8 0 24 hello
o 31 64 0 34 80.0 9.765625E-5 0 -1
You need return at end...
And watch to traffo action.
Scope is across capacitor. Voltage is higher than input.
The sine input doesn't have to be pure. Like Motorcoach and I discussed using a stun gun in place of the sine wave.
forest
gk
that only works for a moment then voltage is falling down
otto
Hello all,
@NickZ
yes, when I connect a bulb I see how the current dropps.
@Lindsay
Its finally time to say a few words to you:
You have always insisted that we use tubes in our tests because its easier to see the "effect" and so its cleverer to use them.
On the other hand Im going the "hard way".
Now I want to tell you my little secret why Im using SS: tubes are "clever", to say so. You cant fool a tube!!
But SS, like transistors, fets, MOSFETs and ICs are sooooo "idiotic" devices that you can fool them in a lot of ways. Some transistors are doing their "job" without a connected emiter or collector, same with some types of MOSFETs. ICs have a little bit other "problems, not to forget batteries that are not only batteries but switching devices.
No, I dont want to go deeper into this thematic.
So, this is one of the reasons why Im using SS.
Otto
NickZ
      @ All:
       The problem with using solid state components instead of the magamp idea, is that Nobody so far has been able to produce and demonstrate any real CURRENT by using a solid state device.  Or, for that matter even a prototype of a working device using a magamp.
  Most all of SM devices have a coil or two, a magamp and a capacitor or two, and thats all, maybe a battery.  Even if his devices were Full of batteries, or, working off of the electric power grid lines, or phone lines, etz...still nobody has been able to replicate his simple set-up.
  Wattsup says that he will show us how it was all faked.  Ok, lets see it.  Light as many bulbs as SM had, with only batteries, that can be hidden in an OPEN TPU.  Forget the closed one with the mistery base.  He has said there are NO Batteries, in front of many observers, many times, to all the men that are there to look for faked components like hidden batteries.
  There must be something to the SM system, with just what is shown in the videos.  Has ANYBODY really tried to make on, just like his, in 10 years?  Yes, No?
  Bolt says that to try using magamps in a system would take forever, but won't even take the time make one himself, as proof of concept.
   Otto says that SS can be fooled to produce power.  But has not shown us how much power they can be fooled to produce, lately.
  Wattsup says the SM devices only work because All of the SM devices are full of batteries, but he won't show us a small working device that is full of batteries (that can start a car) like MITTS Dome.
  GK has made so many coils he's lost count. You get the prize for effort, (hopefully a working device, someday). Looks like he enjoys the ride, and not just the getting there.
  IST says that its not the coils, it the way they are wired, but again stops there, and won't show us more.  IF there is more.
  Sigma16 is the only one that knows all,  but like the Shadow,  he's not telling, or showing, only endless clues...
  you gettin hotter,  no,  now your getting colder...
  Why won't you tell us Sigma? If you really knew how it all works,  you wouldn't be playing games, and hiding behind the curtain. You'd be a rich man, and so would we...
                                         NZ
