do you like this topic?
 no, it is BS
XS-NRG
You only think it is hard.
Once you step into the digital controller world, you can make that motor dance with your eyes closed.
It is not hard at all.
cletushowell
Let go back to the apple
its not a pea in the center its a core
a torus watch this video its the string theory
design but not the structure but its the closest example i can give you
http://www.youtube.com/watch?v=8ey028iq22A&feature=youtube_gdata_player
to help you understand life itself
without weapons now your testing
daves device you see of very important
to controll the energy you need to conduct two
of those pipes oposite the wheel
with a flat plate
this makes your ++
sorry im lost this thread is all over now
i dont know what the goal is so Im
stuck on trying to tell you the answers to the questions
take rosemarys wheel and put two
one upside down on the other
but your just over complicating daves
design you can get all four cirners if earth from daves
rember the cup ill post the diagram give me a minute
cletushowell
sorry I got frustrated on the left side I dont hve the graph paper
Im pretty shure its + -+-+ but its negative the last time i did it so maybey its just -
so the 4 + turn to negative but the point the hit the ball is the point of the polarity and being I dont have a the exact graph the ++++
should go ++++
                 -  so ya it should be right at the very point - but just off the poi +-+ thats the left
sparks
@niiev
    You can split just one pulsed signal by inserting capacitors in series with your coils.   You can try it with just 2 one winding connected directly to the line and inserting various capacitors in the other two.  The combination of capacitance and inductance and pulse width can be adjusted so that the coils appear to fire around the circumference of the motor.  You can get it all to ring also.  This is when your motor windings appear as inductors in 3 series resonant circuits.  This is the most efficient design but as you have already noted it is no easy task.
    You can get hold of Bolt who posts in the TPU section quite often.  He builds rotoverters that is basically an electric motor stator creating a rotating magnetic field that whirls around a fixed winding whose currents are then supplied to a load.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sm0ky2
@ Rose
have you found a way to "polarize" things, different from what Dave showed with the PMH / aluminum?
@ Gravity Block
What exactly would be gained from knowing that a piece of... say Aluminum, has a ferromagnetic quality of (X)
Or that a piece of Copper has a field of (X - Y)
They are not magnetic. but are attracted to a field, when they should NOT be.. its very strange. but im not sure what measuring this will tell us??
im assuming this is temporary, but i guess time will tell. its only been 3 days and the aluminumn foil is still ferromagnetic. I dont know wether or not dave still has his that he did a while back.
Aluminum foil works very well, Copper sheet works to a lesser degree.
im under the assumption that the material has to be conductive, or more specifically, a metal. though i may experiment with crystals..
i guess what im getting at, Grav..
    What exactly do you hope to determine,
with the knowledge of the
precise permeability of a piece of polarized aluminum???
Is there some standard, for causing a mass of alumimum to be attracted to a magnetic field, that perhaps... consumes a given ammount of energy, by which we could use to asses the strength of the magnetic current?
Theoretically, the strength of the magnetic currents' magnetic field should be::
2.8028 x (10 ^ 14) eV / ng
give or take impurities in the metal
up to approximately.....
2.33 x (10^15) ng, then we have a "slightly different situation"
