do you like this topic?
 no, it is BS
cletushowell
Can one of you chemist test this gas
for me i think its the antigravity secrete
i do not beleive its hydrogen it does not apear to be steam
and it instantaniously reversable
so what is it power to aluminum can
in water nuetral to a copper rod
in water a little bit of salt gets it bubbling
good that bubling will lift the soda can
and copper in the right structure
now im a little stuck on the rock
either i dont have enough power
or im not containing that gas now
please help i dont have eds books what did he
have as power someone said a generator
was there how many amps
can someone calculate the size wire he used
and how many amps it can transfer
im noticing two things moray
long 50 cables ed long cable
now I know the polarities i know the
energy i dont know how he harnesed it
so he was either putting in so much it doesnt
need to be harnnesed or some how
that tripod possible held the gas
was there anything like a tarp
that could go over the tripod
remember the ark the covenant was always in a tent
why? I think the vibrations of the powersupply
would shatter a building the egyptians used
a tarp in videos i saw over the rocks
im pretty shure this gas just hits that tripod and then goes below the rock
but what is the gas how does it boil with no measurable heat exchange
please email me ch@helpuflip.com
i need more power or harness the gas
or think harder one or the other or all
david lambright
Quote from: void109 on September 03, 2010, 12:39:28 PM
Almost forgot, I also took 5 1" diameter ferrite cores and cut them in half with a diamond wheel.  I arranged the remaining 10 half circles in the typical arrangement, wrapped coil around one of them and pulsed it to see if I could get it to lock.
No dice, they would forcefully join during the pulse, but completely released afterward every time.
I also made a PMH with a U shaped threaded bolt from home depot, and put a 0.5" x 4" steel bar across it and locked it.  Then placed it in water as I've seen others do and froze it.  I didn't see any anomalies as others had.  The PMH effect was there to be sure.
Do you think it is just the case that when we pulse the PMH it is aligning all of the atomic dipoles, and once oriented, they hold each other in place?  Then when you quickly remove the bar, it is just the dipoles 'relaxing', or spinning to a rest orientation, and its this relaxation that is inducing current in a pickup coil?  While this wouldn't explain any of the effects being discussed here, in this description there isnt anything 'flowing' around the flux path, it would just be the dipoles locked in place.
.....void....try using some thin steel between the ferrite...make sure it is clean...i bet you can get it to lock that way ...but with the oxide, it is magnetically clean and when packed tightly, dry, into a tube, it will hold energy like a PMH...i am making a video on the oxide core devices soon!...you might need only one piece of thin steel to get your device to lock....arrange your ferrite pieces then at one junction separate the ferrite with the steel and re-energize....if you want to..........david
Rosemary Ainslie
Hi Cletus,
We none of us know what Ed did.  If we knew we'd be able to do the coral castle build.
Kindest regards,
Rosie
Hope
Thank you for your time all,  this is very interesting subject to me.    When gravity changes the photons (particles of all types i image too) reacts to it like a pressure.  High gravity may squeeze the photons close.  The neutral space gets changed also, since current travels both ways at the same time in what is believed to me a helix shape.  Then if we can split this helix (maybe using a small hole made using a neutral magnetic field) then we will have unbalanced particals (could it be anti-matter) which will seek to become balanced upon exiting the magnetic hole field.  This will be hard to follow   sorry.   The glimmer maybe the energy caused by the neutal squeeze balancing its self.   So this helix's circumference varies.   Which maybe a key to expanding a helix enough to cause its natural bonds to weaken.
Rosemary Ainslie
Quote from: Hope on September 03, 2010, 06:35:06 PM
Hello Hope. No-one knows what causes the Lambright Effect and I'm absolutely sure that your explanation here is as good as any.  I'm not entirely sure that I follow it - but it's good that it makes us all think.
Kindest regards,
Rosie
