do you like this topic?
 no, it is BS
sparks
      The energy of the Sun is not derived from nowhere.  It is garnished from its trip through the vacuum which is full of  very heated electrons and neuclear cores.  Heated to the point of total seperation of individual particle to particle behaviour not displayed on our list of "elementry" particles.   As the sun encounters space plasma it converts it into Sun plasma.  The sun is continously producing a magnetic field that manipulates the space matter to cool.  The corona is produced from interstellar hot electrons cooling or slowing down,  The light we see comes from the corona not the Suns core.  It is way too cool and dense in the Suns core to produce light.  It is total bullshit that a star is some sort of  energy producer that suddenly runs out of fuel when the hydrogen fuel runs out.   It is an example of negative entrophy.  We are examples of negative entrophy.  The space plasma critters that run around and check out our glorified bullets with people inside them are examples of negative entrophy.  The magnetically self confining plasma they create in vain attempts at creating fusion overunity displays negative entrophy.  The Sun is alive in this sense.  It is not worthy of adoration as the giver of life but most if not all religions were created by Sun worshipers.  Luciferians.  Luminescent Lucifer.  Lucifier presides over hell.  Hell is said to be hot.  I guess if you dont do what the priests want you to do you are condemned to residing in lucifers hometown which would be somewhere in the vicinity of the big selfpinching plasma ball 92 million miles away.  What priests want you to do most is show up at the temple with an offering.  The exploitave Egyptian barbarians enslave african natives to do their work for them while they run around adoring a multitude of gods.  They build this ridiculous religious theme park on the blood sweat and tears of enslaved men.  They exalt themselves to the level of Gods by using technological "secrets" passed down from generation to generation of priests who at one time witnessed the remnants of the greater older civilization.  There are symbols of spaceships ascending through electrcal grids in there.  There are pictures of guys with one wire flashlights there is no soot from torches  in the great pyramids.  No hiorogliphic images of what this pharoh did or that one did.  The word is that the greater civilization has returned for a look around and they aint happy with the priests.   It is of interest to note that the human eye is able to detect heat waves and this device appears to produce a mirage.  It is almost like what the Sun does.  It takes electrons and causes them to change their velocity into less velocity which always creates photons.  Investigate advances in electrostatic cooling.  You will be amazed at the amount of furor this subject raises in the political systems we find ourselves having to cohabitate a planet with.  If you can electrostatically cool your medium you can convert thermal energy into electrical energy without the use of fuels and without the limitations of carnot cycle.  You get what is called negative entrophy going where chaotic thermal energy is converted into the more ordered form of electrical energy.  That is what drives a Tesla magnifier.  The thermal energy of the atoms in the spark gap is converted into electrical "pressure"  Tesla stumbled upon it when he was attempting to quench his spark gaps.  The relatively hot gas entering the spark gap leaves the spark gap cooler.  Where did the thermal energy go.  He latter quenched his spark gaps with magnetic fields.  Again cooling down fast moving electrons in air molecules to emit higher frequency photons. He was a student of Crookes.  Crookes had to defend many times that the light was coming from the gas in his partially evacuated tubes and not from the cathode.  The electrostatic potentials developed across his tubes cooled the air electrons into emitting light as they cooled.  Tesla took regular vacuum tubes made by Deforest and pumped air into them. Drove a car all over the place fueled by warm air.  The first thing he did with his vacuum tubes is change them into not vacuum tubes but air quenched spark gaps.  The arc of the covenant is an air quenched spark gap.  The fog that surrounds the device is fog.  What happens when you cool down moisture laden air quickly.  It gets foggy.  .  The military ufos do this.  They condense plasma into hot gasses.  The latent heat of condensation of plasma is used to power the craft.  The destruction of jet engines with supersonic expansion of plasma in the outlet of the throat of the laval nozzle is because of the latent heat of plasma converting into low frequency acoustic waves that resonate in the expansion chamber until the engine acoustically disintegrates.  The guy after Crookes that named this form of matter plasma was really tuned in.
Before that it was coined radiant matter.  Matter that radiates energy.  Faraday was the first to refer to the possiblity of a phase of matter existing beyond that of a hot gas and named it radiant matter.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cletushowell
My notes are gone there covered up by illumianti
post at least i cant get them on my phone maybee on a computer im pretty upset what a bad day 10 2 7
1 circle charge the rock 2 energies
7 =16
Sorry im trying to put what i remember
1027210
10-2=8.       10-2=8
             88 =2 eights
8+8=     16=7
1+2+7=10
oh im so stupid 7 star of david actualy has eight
points all dementions this is why man is forgetfull in nature and
ed built the valintine with the rose
to remind him i should built one too
i guess
sm0ky2
@ Hope
We need something that reacts/vibrates at or around the frequency of magnetized iron. (~281 Ghz)
My thoughts along this line are some form of Piezoelectric Crystal. i know some of these can be grown, but my skills in this area are about as bad as my drawing.....
Also i don't know a lot about how to construct the dimensions of large crystals to get them to resonate at specific frequencies.
When i get to that stage, i'll probably need a lot of help..
My "vortex" was not drawn good at all, it was just a hasty attempt to show cletus what he was asking about. about the position of the spherical fields. i cant really draw them the way they should look....
i think what we're seeing is actually eminating from this.
Look at a lightbulb from the side, at a distance.
you see the interference pattern radiating out,
just like Dave's device produces,
just like that black&white image i posted a few pages back.
but the way it behaves., (this may sound silly) is like the light itself is magnetized? polarized? i dont know the word im looking for,. but the waves radiating out are attracted to the field of physical matter, drawing the light towards objects placed near it.
I figured out what we need to detect this
most IR recieving equipment has a low-band cut-off at 300Ghz
we need to either remove this restriction,
or use a high-band microwave reciever to detect the energy.
this reciever may not exist,. the closest thing i know of myself is a little hand-held gizmo they use to safety-check a microwave oven for electro-radiation leakage.
but unfortunately for us, these meters do not go up to a high enough frequency for what we need of them.
most anything else i can think of is designed for recieving high-power outputs, and im fairly confident that this is a low-power / residual power type device. at least it its current designs.
There is a passive-bridge microwave reciever, used in telecommunications years back that may work as an oscilliscope input.
they use a passive antaena, and then amplify it, like a radio.
i know these can hit up in the 296Ghz range, so 281 should be no problem. i'd have to track down the exact name of the things. possibly find one surplus, or used. as they are obsolete in the industry and no longer made.
picking it up on a scope, and dividing out the recievers amplification values, would give you the power output of the portion of the field the antenna recieved. simple area equations give us the total field-power of the device.
sparks
  arent there radar detectors used to detect cops checking your speed.  Fuzz busters.
Think Legacy
Spread the Love
cletushowell
Wow sparks that was alot i did manage to get it all
i knew the pressure in those black lights were backwards
im really limited your right about the sun but a bit off
the sun is not from particles in space
it from the reflection of the seven stars
the mystery of the seven stars
but its no hydrogen ball is there good weather in
canada i went one time on the cruise to alaska
id like your help you know.
Maybee im beyond help
