Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Omnibus
Quote from: Ted Ewert on September 07, 2010, 11:52:21 AM
May I suggest that we ignore Omnibus and his attempts to discredit this fascinating phenomenon. Whether he is a troll, attention whorre or even an owner is really besides the point. He is trying his very best to derail this worthy topic and we are playing right along.
Don't reply to his inane posts. Don't feed his pathetic need for attention. Don't acknowledge his idiocy as worthy of a response. Don't get sucked down into his negativity and don't allow him to hijack this thread.
Let's stick to the NS coil phenomenon and see if we can figure this energy source out. It may be just a galvanic battery working off the moisture in the air, but that is still to be determined.
Nevertheless, any device that can produce electricity for a long period of time without physically deteriorating or having to be replenished is certainly worthy of study and replication.
Cheers,
Ted
Yours is really idiocy, indeed, to suggest that this is a fascinating phenomenon in the same berth while acknowledging it's a galvanic battery. Galvanic cells are well known and there's nothing fascinating about them. Who needs enemies if one has advocates such as you. Pathetic.
Omnibus
Quote from: Pirate88179 on September 07, 2010, 10:17:18 AM
If you have read or are familiar with the Nathan Stubblefield Earth Battery Self Induction Coils topic located here:
http://www.overunity.com/index.php?topic=3500.0
you can see all of the research done on the patents and the devices.  This took a long time to compile this information.  Did you know that Stubblefield is recognized here in Kentucky, at Murry University, as the Father of Radio?  His voice transmissions preceded both Tesla and Marconi by several years.  He sent the transmission through the earth and his transmitter was powered by the Stubblefield cells.  He also installed the telephone system in Murry, KY and powered the entire system from his earth batteries.  He also lit his farm and heated his home using nothing but his earth batteries/Stubblefield coils.
So, we know there is something to all of this.  There was NO grid power in his area of the state at that time and therefore no radio/tv transmitters either and yet he said you can get all of the amps you need from the earth for free, and he did.
This is why I do not see the need for the Faraday cage experiments as I am satisfied that is not where the energy is coming from.
With a little reading on Stubblefield, you will see why this is all so very cool to finally be replicated by lasersaber.  It worked back in the late 1800's and it works today.
Bill
This is all well and good to admire a local hero, however, there's absolutely nothing in this so called Stubblefield coil. We're talking about the coil, right, not the radio or anything else? I took a glance at the thread you mention and I assure you, it's sheer waste of time. Absolutely nothing of substance in there. You know, many times there are these made up folk heroes who fill in some gap in the emotional needs of a certain area. I don't blame the people in awe of the hero, I blame the clowns such as this certain Stubblefield who has fooled successfully so many. That's a shame. These phony heroes foist themselves on society and substitute for the real heroes who are are doing the OU, standing in their way and thus hindering the real progress. Like I said, let's get to the bottom of this with real concrete data so that you can make it known to the people of Kentucky what fools someone was trying to make out of them.
dllabarre
Reposted from 4 pages ago.  It must have gotten buried in all the "name calling" crap over the past 2 days.   >:(
Whenever I search for iron/metal rods they all have code numbers.
What is soft iron: "1018 Cold Rolled Steel Round Bar"?
Or something else.
I'm not looking for a core thats "good enough".
I want to buy what works "best" for the core and if it's too expensive what's "second best".   ;D
What size (AWG) copper cotton insulated wire and iron wire to buy and where to buy if possible?
Thank you,
DonL
Rosemary Ainslie
Cheers,
Ted
Hi again Ted
I agree entirely with this.  Surely to use water instead of electrolytes has got to be an improvement.  Just so much cheaper, cleaner and more accessible.  Then - if one does not even need that water - then it opens whole chapters of interest in our researches here.    I see NOTHING that is not improved by progressing this.  Cheaper lighter cleaner batteries is just the start.
Rosemary
powercat
Quote from: gauschor on September 07, 2010, 06:52:22 AM
I have watched all videos now and I also think that the moisture persists for a long time within the different layers of the coil. It remembers when I put once copper and iron into box with wet sand and could measure some voltage for some months time. And exactly this seems to happen in here, which is nothing unusal I'm afraid. The solution with salt water will most likely only dry out on the outside, but not on the inside completely. As powerthecat already mentioned, it is difficult enough to remove moisture from the inside of a transformer. With this kind of NS coil it's even more diffcult.
Also I agree with omnibus that you need to enclose the device in a faraday cage. Make sure you are not in the near of an electrical distribution board. I experienced myself that I could pickup a decent amount of voltage and current by just having a long cable next to some board, as well as in a distance of 1-2m. Since you have quite along cable (coil) this device will act as an antenna and pickup electromagnetic waves very easily! This is most likely the reason why it even works in a dry state.
Of course a faraday cage will also dismiss natural electromagnetic waves, but you'd need to go into the desert to prove the influences. I agree though that this device is interesting, but all in all it seems to be a galvanic cell only (wet state), or anj EMF pickup antenna (dry state).  :(
If it is possible to gain enough power for many month or even a year just by using this device and putting it into a box so that it is shielded from wind, I could imagine further use though. For now the "motor" however seems to be quite weak. Even a small flat battery cell has more power than this big device as can be seen in one of "lidmotors" replications. Therefore it needs lots of coils  :-\
Hi gauschor
It is more than likely that we will see a faraday cage test done in the future,this thread is looking like it's going to run into hundreds of pages.
As to the question of moisture and decay in the coil, I think this all depends on how long it will last, if it turns out to be a very long time,hopefully a year or two, then the amount of decay is negligible
@all
How many coils are going to be needed to produce 1 W of power, and what is the cost of materials to make these coils going to be in relation to the amount of power produced over time.
This is a question I hope will be answered as the thread progresses  (if it can)
I really don't care if someone posted a device on this forum that ran on lemons, oranges,
or toilet paper, as long as it made power for a long time at very little cost,I would find it interesting and worthy of further investigation.
I hope that when Stefan gets back he will tidy up this thread.
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
