Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
LtBolo
Quote from: core on November 24, 2010, 05:23:38 PM
The answer is he has no idea how to replicate Tariel's design.
If you have the capability to do 5kw why brag about 400 watts? makes no sense to me.
I don't think he claimed to have Tariel's design, did he? I think he only claimed to have spoken personally to him. Does that give him some insight? I guess it depends on what Tariel told him.
As for 400W, that is based on SR's output...which was shown to apparently be self sustaining. If true, that's big. If Cosmo knows how it works, I'd love to know too.
Obviously, given the knowledge, I'd far rather build Tariel's than SR's...but...SR's will change the world as is, with or without Tariel's. I ain't choosy....I just want something that works.
sigma16
Quote from: Shokac on November 24, 2010, 05:36:13 PM
Maybe yes, maybe no. In 100kW Kapanadze device don't have ground. Kapanadze says that in this device use Y-load 3-phase circuit, and center is N. (No Ground)
Mr Kapanadze tell us which principle you use in the installation.
This copy is based on the well known law of the lever.
How does, we take a small portion of total energy network using Tesla coils get hundreds of thousands of volts and send it through the spark gap on the current amplifier.
The principle is identical to the lever.
Correspondent.
Mr Kapanadze we are well aware that the lever worked he needed a fulcrum, where it is in your setup?
You're right, in my installations up to this, I used ground, which is rapidly destroyed by the processes occurring in the soil around the pin. Ð'
In this installation, I compensated by the lack of three-phase inclusion of a star.
Correspondent.
Others:
http://next-energy.ru/forum/index.php?topic=40.msg5752#msg5752
The following is a possible interpretation of the statements by Kapanadze, regarding having a ground or three-phase "Y", based on an entirely different concept of operation put forth by Grumpy on another forum, which he derived from work performed by Dr. Harold Aspden:
(When CosmoLV steals my words for his explanation, remember that you read it here first.)
1. The device with the ground connection does not have a rotating field
2. The three-phase "Y" produces this rotating field and a ground is no longer required
3. The rotating system is able to produce a charge separation directly.
iceweller
Attached you see a screenshot of the removed coil with cut connections. Everything looks coaxial, even if coils are shifted, the magnetic domain must be shared. Outer copper coil (load coil) has it's feed connection from the green box cut off (the green HV neon trafo wire comes from SG1 and goes to the coil but not sure how it's connected even if I have some russian schematic saying it goes to primary internal winding) while the other end is still connected to the "stray" orange wire. I don't see any external shield - it appears to have an ordinary core unless it's hidden between layers(!). A schematic indicates a second SG supposedly connected to the big copper coil - I fail to locate it (unless it's hidden in the core or box) - though I doubt it's 100% reliable.
The second screenshot shows an alternative gnd setup with the second "load point" or ground connected not to the black center wire (always gnd) coming out of the core of the coil but directly to the gnd wire itself connected with an extension (lower left side of pic). Note: the device was not connected to the inverter/UPS output yet as the plug still lay on the table (which was connected shortly after they realized it wasn't working).
core
Quote from: LtBolo on November 24, 2010, 09:11:08 PM
  With the exception of the ferrite all other speculations have been based of Tariel's device including stating that Tariel has standing waves in his ground wire. Tariel has stated he will not share the secret with anyone. Cosmo has stated that Tariel does not share everything with him. Why would Tariel share anything of value with Cosmo?
  There is no evidence, other then one video, that SR has a device. When questioned by his comrades he disappeared. Anyone who makes a FE device has to know that questions as to its authenticity will arise. I am sure SR, prior to his video, was also a skeptic at one time. On the Russian site that was linked above 3/4 down the page there was a quote from Tariel calling SR a 'charlatan'
  I am not sure how 400 watts will change the world. I am not buying into the fact that the world will hold hands and sing 'kumbaya'. I'm sure you remember 'Hands across America'. Cosmo has stated that 'You can not get out more then you put in' That applies to Cosmo's unit it is unclear if that applies to Tariel. Scalability may not be realistic Cosmo has stated it is very difficult to get 600 watts.
  What is strange is why is everyone, including myself, is chasing a ghost when Tariel has 10 video's including the 'plexi-glass' unit that shows a very interesting coil composition?
   Anyway what are your thoughts on the Kodak flasher?
Respectfully,
Core
sigma16
I'll have to check the video of the garden coil demonstration again, but can anyone tell me if Kapanadze connects the battery to the system to start it before he runs the system without that battery?
This is very critical.
EDIT:
OK I just looked at the video again and you must start the device with a battery before you can run it in a looped configuration.
So, it will not work without the load being powered.  How very interesting!
If anyone really has an OU device, and it is so easy to make, then he can tell me why power must be applied to start the device before it will self-run.
