808 G6 OSIRIS ENERGY TECHNOLOGY
Started by osiris, December 03, 2010, 09:33:16 AM
osiris
for the 16.2vdc banks i used copper water pipe to connect the caps 1/2"
i used 3/4" copper pipe  on the input cap bank
osiris
osiris
here is the compleated structure ...
there are a few nuts and bolts required...   ;D
here is the compleat cap bank
osiris
so look at it like this ...
ITS KIDS PLAY ...   and WE WEAR CROWNS !
8)
watch this ....   the invertor draws at 60 hz ...  LMFAO!!   fact !
regards ...
OSIRIS ..
simple charge them at a higher rate of time !
time is based upon 60 hz  my rings run MHZ ..... yawn ..  aswell this ring is designed to multi pluse  the G6  coils 3 times per pulse   per dirrection ..... so  this means i pulse my ring and  i harvest 36 pulses from 1 and recover the first pulse ...... in the second 808 supply
808 is a flip flop design
aswell the coil design increases freqency  BIGTIME!!
im simply converting electrics to magnetics and shareing it ..  via the ring and increaseing speed by virtue of windeing aswell i recover the colapse .. but the coil only borrows the engery
from the first cap bank and sends it to the second ..
so think about
if your asking for my work it is because you do not understand your own ..
nievesoliveras
Take this and use a good charging circuit with a voltage regulation runned by any one of the capacitors.
It could be a joule thief charger runned from one of the capacitors.
Just an idea!
Jesus
I must add that this configuration is in series and it will increase the farads.
The same idea but in parallel will increase the volts.
FatBird
