Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
shylo
Hi Lasersaber ,It took me all day but I finally got to watch your latest video ,totally amazing!! I see how you added a secondary coil because you said you burnt out a couple of transformers . Can you give more info on what types of transformer can be used , were they all identical or is there some tolerance there, also pin #'s. I wish I had half the talent you have keep up the great work!.......I have two caps that are 12000uf 56wv ,is this 56 volts??They charge up to 5volts after 15mins hooked to 2.4volt water battery, does this make any sense??......sorry for rambiling just have a thousand thoughts running through my brain,you can probably smell the smoke lol..........thanx shylo
stprue
Fantastic vid LS! WOW
This circuit seems so simple, I bet you could run this thing off of a solar calculator cell because it seems to drain so slowly.
Keep up the inspiring work
The Observer
Joule Ringers,
---> Thanks to everyone for your research and experimentation. ! <---
I have a suggestion, I think Gadget has mentioned something to this effect.
However, I would like to state my version of it.
Use an Untampered Camera Circuit to charge the Joule Ringer's Capacitor intermittently... with a 1.5 V Battery.
                                                Fuji Camera Output ----> Capacitor -----> Joule Ringer
                                        Because the basic Camera Circuit can charge a 300 uf Cap to 100 V
                                                       in about one second from a 1.5 V Battery,
        this might be a good idea.
GodSpeed,
                The Observer
nievesoliveras
@observer
Exactly that is what I am trying to do.
To have a high voltage circuit that fires itself once each minute or once each hour to replenish the power source with a strong spike that will be accepted by the running battery without affecting its work and maintaining the circuit self running until the battery gets to its charge discharge limit.
Jesus
neptune
@the Observer. Charging the cap to 100 volts will almost certainly blow your transistor .
@ lasersabre . Not everyone has a camera transformer . What are your thoughts on making your own on a toroidal core . Could you perhaps suggest a suitable core and turns ratio ?
