Bob Beck Protocol for curing AIDS and Cancer
Started by matthew6060, January 05, 2011, 04:18:04 PM
papazaf
MrMag you r right
but i think , if the frequencies are correct, i would be easy to drive them into the body.
to my eyes, rifle and all the other are around the same principal.
the way of apply it varies?r u agree?
MrMag
Quote from: papazaf on January 16, 2011, 04:01:46 PM
MrMag you r right
Yes, I guess I agree. Beck and Clark's units are directly connect to your body. Lakhovsky and I think Rife's were more of a non contact unit.
With Beck and Clark's device the current will travel through your body from probe to probe through the path of least resistance. Since your body is mostly water, it would probably be directly across from probe to probe. It would also more then likely pass through or follow some of your veins. I don't think that much if any of the current or frequencies would get into any of your organs. So, if your looking into cleaning out the parasite and microbes in your blood, these units theoretically should do the trick. If your problems lie in your organs, you may only see minimal results if any.
Rife's and lakhovsky's unit transmitted the frequency to the body. Lakhovsky used two antenna's and the patient would sit between them. The frequencies traveled through the body from transmitter antenna to receiver antenna. He also use a probe to concentrate the frequencies to specific parts of the body. I could be wrong about Rife but I think he used sort of a focused beam to the treated area.
papazaf
is there any Lakhovsky device ,circuite plan availabe to build?
i have only found finished devices, and they cost a lot.
MrMag
Quote from: papazaf on January 17, 2011, 01:04:38 AM
Yes, the schematics are at this site  http://users.skynet.be/Lakhovsky/index.htm
I would be careful about buying any units that are for sale on the net. You need to make sure that they were built the same as Lakhovsky's original devices or you will not get the same results. This also applies to the antenna.
