High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
0 Members and 17 Guests are viewing this topic.
RichardDay
Hi Ironhead,
You mentioned that this new cell acts like a capacitor. Am I right in saying that you pulse the cell until dialetric breakdown occurs? In order to do this you would need a blocking diode to prevent the electronics flowing back when the voltage is at 0V wouldn't you?
What is the voltage actually reaching the plates? Do you have it stepped up or is the 36v DC already stated?
In the video you've got what looks like a coil connected in series with the cell. Is this used to charge the plates using the collapsing field effect when the voltage drops to 0V? A lot of questions I know, but this has to be the most efficient process to have been captured on video!
Am putting together the cell as we speak, once I have the electronics figured out I can get on with connecting up to the engine.
Gentlemen, start your engines!
IronHead
Show me pics of your cell when the basics are complete ,the cell itself.
Then we can talk about what it might take to make your cell perform.
All cells require different controller configurations and some require no controller.
To everyone else here ,I don't care what  your cells are producing.
I want them posted here. I want to see who are the DOers
and who are the LOOKers. If you build it I will help you make it run.
I have found that you can get high production from a single 1/8 rod
or a hundred Stainless pates, it does not matter. What matters is
how you power that specific cell and what you are going to use it for.
One thing at a time
Do Not let the posters discourage you by saying
"well that cell is not producing like IronHeads"
Its not about who is better it's about evolution
of this technology. We will learn from each other.
Some of you sit back and wish you had high tech
reactors that are laser injected with massive circuits
shinny and new like a space ship. Forget it!
Go to the the scrap yard and dig up some stainless
or cut up you kitchen sink. JUST BUILD IT!
If you are worried about
making mistakes and trashing cells and controllers,
then keep burning that gasoline as you will never
achieve a cell without taking risks.
I say what ever it takes
JUST BUILD IT!
IronHead
IronHead
mramos
The electronic board is not going to help this cell, yet
Lets get it working without electronic first then start thinking about pulsing
With low Volts you need higher amps to build a good strong field
12VDC just don't seem to have what it takes to get a good field going
, but will work. Control the amps to start with using KOH
Dump the skinny highly resistive wires and put in
some good multistrand audio 8 gauge power wire.
Also the plates are to close together and will short to fast.
What kind of water is in there and is there an electrolyte?
Finally it looks like you are drawing power from a power
supply or battery charger ? If so get yourself a battery
and connect the cell to it and the charger to the battery
as it was designed .
One more thing.Take those plates out and see if you can
stick a magnet to them. If the magnet stick strong dump
them and get some non magnetic 316 SS. If these are
316 and have a little magnet pull then put them in the
oven for about 1 hour and bake them.
Built
IronHead
rapttor
Quote from: IronHead on April 04, 2007, 10:51:53 PM
There is just to many things in tap and ground  water that turn to poison for me to use in an open cell like this. Stanis Fluoride , Copper, Florian, Chlorine , Hydrocarbons , and all the other wonderful things that leach into our water systems.
Ok, so it's not just me that noticed this. I've been doing some preliminary tests on some SS I have with a Variac, with rectified output, and the other night I noticed right away the instant brown coloration showing up in the water, then a Chlorine gas smell which prompted me to immediately shut the cell down fearing that I would poison myself. I thought my taste buds were fooling me when I thought I could sense alot of chlorine in the water.
And people wonder where all their health issues stem from.... it's right under their noses.
thanks for throwing that in there, I may have let it go another few times and ended up making myself ill.
-art
Successfully Perpetually Failing at everything I do...
IronHead
Ok  lets see the current cell build. With info when posted
