Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
Magluvin
Like I said above, I had fiddled with this for a bit. I was thinking a bit on it today and there may be good use for it. Romeros setup has 2 poles adjacent facing out, so I assume the alignment with the core need be close, due to the 2 poles having tight connection and not too much field escaping that grasp. But close to the edge of the rotor, the core will see an immediate shift from n to s as the center between the mags passes the core. It might be interesting to see what multiple switching may do here.
I remember Zeropoint132 had the self running no bearing bedini sphere. 1 reed switch, 4000 turn bifi I believe 26 awg and 30 awg, a couple diodes a reed switch, 10uf cap and an led.  Maybe if the bifi, if we were to hook it up in series, the way we have seen, except with a diode that allowed conduction during generation, would charge the capacitance of the bifi which should be large, and then discharge with a reed across the diode so the current would flow the other direction causing and opposing pole to the spheres pole, that just passed, and then recycle. I have to find that drawing, it could be the charge is discharged into just the 26awg via another diode.  I have to find it, as it may use the reed to do what we are discussing here.  Be nice to get a simple runner.
ZP had issues with the vids that had shown schem. and was told not asked to take them down. Said it was a military thing.
Mags
romerouk
Replaced the reed from the driver with a hall sensor driver.
2 coils running in shorting modem, better output.
I have been asked to show my device when not rotating.I am attaching the pictures below.
romerouk
Quote from: romerouk on February 19, 2011, 09:15:17 PM
2 coils running in shorting mode, better output.
Magluvin
Hey Romero
Sounds good.  Have you tried any looping?   I need to try this, I need to see no drag.  =]
Good work!  ;]
Mags
romerouk
Quote from: Magluvin on February 19, 2011, 10:09:11 PM
Hey Romero
Good work!  ;]
Mags
I have tried looping but with a battery in the system. Started with a 6 volt battery at 4.1 volts and after 4.5 hours the battery shows 6.3volts.With a capacitor works for a short while(like a minute) then it looses the charge. Maybe with a supercapacitor will work better but I don't have any.I will add more coils tommorow and see if I can replace the battery with a capacitor.I don't see any drag when using this type of coils.
